20 Most Recent
Cisco Linksys E2000 Advanced WirelessN Broadband Router Network Routers Questions & Answers
Moved from usa to denmark
that would be logical considering that there are 2 different countries with completely different network systems
Hi, After flashing dd-wrt.v24-15508_NEWD-2_K2.6
Since you flashed your router, you need to reset your modem as well, so it recognizes the "New" router. Turn off both router and modem. Turn on modem first, give it a minute to boot up, then turn on router and you should be ok.
I can't do a speed test with my Cisco router.
Are you able to browse any other web pages through your router? If you are not able to view the speed test page alone, Then it might be a flash problem. Most of the speed testing pages uses flash and you might require a latest flash player to be installed on your system.
You can better visit
ScanmySpeed.Com to test your internet speed. This website doesn't require flash to test internet speed.
How to open facebook when blocked from cisco router
1.login to your linksys. 2.go to access and restrictions.3.click the drop down for access policies and for each selection,check facebook has been added to the url section.4.if found, you can either delete facebook from that policy of disable the whole policy.
Linksys E2000 keeps disconnecting
Disconnect the power from the linksys for about 30 seconds then plug it
back and see if it stops dropping. Most times the dropping occurs if
you turn the modem and router off at night then when you turn them back
on the router boots up faster than the modem and that will cause it to
drop. Power outages also will cause the problem if the router boots up
before the modem.
If unplugging the router and waiting 30 seconds does not solve it then
unplug both the modem and the router. Then plug the modem back in and
let it boot up for a minute or two, then plug the router in and let it
boot up.
How to set up password on router
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router. Connect a LAN cable from the Linksys to the LAN port on your computer. Open a browser and enter the Linksys configuration URL http://192.168.1.1 The default login = admin The default PW = admin You can protect your router by changing the default admin PW (write it down and put it in a safe place) Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption. Now apply these settings to the wireless card in your laptop/computer. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Wrt160n vpn error 800
Error 800: Unable to establish VPN connectionThis issue may be caused by a router that has outdated firmware.Make sure that
port 1723 is opened on your router.For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.I will suggest you to upgrade firmware on your Linksys router.After upgrading the firmware, reset the router to factory default and reconfigure it manually.Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.See How to setup Linksys router
Want to put lock on guest set up
open your browser to 192.168.1.1default login/pass is admingo to wirelessgo to wireless security and apply a password to your guest network.
Can not get into e2000
Who is your Internet service provider?If it is a DSL company then in some cases the router IP address may change to 192.168.0.1.What happens when you try to open 192.168.1.1.Does it ask you for user name and password?Did you install router using cisco connect software?Open cisco connect software.go to router settings.Click on Advanced settings.It will open the setup page.See
Linksys E2000 router setup
Escribe your Linksys E2000 Advanced
Please check whether your computer's wireless connection enabled or disabled. If you are using windows 7 this information you can find in network sharing center. By accident if WLAN is disabled it can be enabled. Also power cycling the router may do the trick.
More drastic approach is resetting the router which I recommend to reserve as last resort. With information you provided the router seems to be fine and your computer wireless need to be enabled!
good luck!
Im trying to install Linksys2000 to my computer ,
Normally userame and password of linksys Router is admin and admin respectively, if it is not changed,
if still can't access, you can reset your router by pressing and holding reset button for few seconds,
Thank you, Please don't forget to rate me.... please
Can I change the broadcast
yes you can change it.
Open an Internet Explorer browser page on your wired computer(desktop).In the address bar type - 192.168.1.1 and press Enter...
Leave Username blank & in Password use admin in lower case...
Click on the Wireless tab>Click on Advanced Wireless Settings...
Change the wireless channel
Also,Under the Advance Wireless Settings on the router,Change the N Transmission Rate to 15-130Mbps and click on save settings
My router will not connect
Make sure the power cable jack in the router is not clogged with anything and that the actual cable hasn't been worn down and still fits. Besides that, you could try unplugging your computer, and plugging the router into that outlet to see if it's not a bad power outlet. If it still doesn't work it might just be time for a new router.
