20 Most Recent
Acer eMachines E7254520 Notebook PC Questions & Answers
I face a problem to video chat with my e725 notebook
old post and NO OS stated.
is this it the true name>? must said first as fixya does not have all 10,000 names for acer PCs here. so must be said first.
Acer eMachines E725-4520 Notebook (the dash matters)
acer both them and gateway and packard bell long ago.
2009 made states your manual.
runnng VISTA , unstated by you and IS KEY fact ? what OS?
ok lines are 2 reasons,
1: overheated PC. ever clean it in last decade? fully, all vent paths all.
2:
bad LCD, 2008 bad GPU, sold by many. then., all bad.
if this is your GPU it is ok. but nVidia 2008, is no good.
Intel GMA 4500M
your GPU is this, if you told last 4 digit of model correctly 4520
E732Z bios password problem
Try to leave it blank and hit Enter or if is not work,you need to manual reset your cmos battery to remove the password. feel free to ask.
Touch pad off
Goto controll panel and uninstall touch pad software, or remove battery then insert again.
Emachine factory reset
original from ja628
try this
(1) Go to start menu
(2) Click on all programs
(3) click on Emachine
(4) click on Emachine recovery management
(5) Click on restore on the bar across the top
(6) click on restore to system factory default
It takes about 20 mins.
this will only works if the recovery partition is still intact or you havent deleted it or format it in anyway.
if the above process dont work, you can insert cd installer and choose repair then go to recovery option
Laptop emachines e725 overheating
Could be simply a blocked CPU vent, clear with a can of compressed air. Make sure Fan is spinning when you power up the PC.When the fan is spinning place the back of your hand by the Vent you should feel hot air. If you feel cold air the CPU heatsink may need to be reseated with fresh thermal paste. Worst scenario is the Heatsing has Failed and needs replacing.If the Fan is not spinning it may have failed or a lump of fluff has jammed it
Usb device not detected
it is u r Acer eMachines E7254520 Notebook motherboard problem if u able to open it then i help u or otherwise go and find an expert for u r notebook motherboard repair.
