20 Most Recent
Systemax SYX Crossfire X58 Gamer Intel Core i7930 28 GHz genuine Windows 7 Home Premium 64 Bit 12GB (SYX1040) PC Desktop Questions & Answers
Change boot order bios
Go into set up usually f2 on start up, you will find boot configuration with instructions
The computer won't boot Windows
It sounds like either Windows 7 did not install properly or you have a bad hard drive. I did some research on similar problems and most people have also tried to change the boot priority with no luck. If your are tech savvy I would try to run hard drive diagnostics and possibly reinstall Windows 7. If you are not very technical I would suggest taking it to a competent pc repair technician.
Systemax desktop boot diskette
do you need a boot disk? do you have one but it doesn't boot?
if you can provide with more information about your situation.
11/9/2015 2:45:41 AM •
Systemax...
Answered
on Nov 09, 2015
How do i get wifi on my laptop?
On laptops without a dedicated WIFI power button, usually the wifi is turned on via a Hot Key. Look at the FUNCTION keys on the laptop. Are there any BLUE symbols there? If so, these are Hot Keys. One of them should look like an antenna (or a magic wand!). Press and hold the FN keys (down next to the WINDOWS key), and press the Hot Key. These keys work on a toggle-on, toggle-off basis. Once is it on, do it again to turn it off. Once you've tried this, look for the WIFI indicator light to be lit.
3/2/2015 5:04:47 AM •
Systemax...
Answered
on Mar 02, 2015
Where can i find specs for my systemax venture desktop
there are specs inside the case, on the bottom, for my systemax venture. there is also a serial number on the back of the tower, on the outside; however, i believe that the systemax desktops were actually assembled by tiger direct.com.
12/28/2014 10:42:34 PM •
Systemax...
Answered
on Dec 28, 2014
What is red light in tower for?
The light in the tower indicates power is going to the motherboard. It is helpful since it is never a good idea to mess with a powered motherboard.
7/31/2014 7:06:52 PM •
Systemax...
Answered
on Jul 31, 2014
