20 Most Recent Canon Pixma iP2700 InkJet Photo Printer Questions & Answers
press and hold the circle with inverted triangle buttons for at least 5 seconds.
printer will self-restart
after this error blinking is gone.
Canon Pixma... | Answered on Sep 03, 2019
how to reset my canon ip2770 printer
Canon Pixma... | Answered on Aug 08, 2019
Hello thanks for using FixYa
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps. I hope it works
  • Turn off printer
  • Remove both the cartridges from the printer
  • Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
  • Return the cartridges
  • Turn on the printer.
Error will be removed
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Canon Pixma... | Answered on Jul 26, 2019
Canon IP2700 6000 Error
Error 6000 tells you that the paper feed roller is not turning, check for any foreign objects in the paper path, a flashlight and small mirror is the best way to look.
yes.. i agree on this statement..
just try this one., its tested by my own experience., first turn off the power of IP2700 printer
then just try to turn the gear of paper feed roller in order to release
the foreign objects..
if error persist, just try to turn the gear again until it works ok.
pls send feedback if its work., salamat., mabuhay pinoy.
Canon Pixma... | Answered on Jun 26, 2019
The print head has a voltage fault. This is usually caused by the logic board going faulty and sending too much voltage to the print head. You will need a new print head and main logic board. This would probably cost more than the machine is worth. Buy a new printer.
Canon Pixma... | Answered on Apr 20, 2019
there is a problem in the gear during initialization of the printer, maybe there's a tiny piece of paper that cause the gear wont move, the best solution is to open the printer to see if there is a foreign object inside in it.. that's all
Canon Pixma... | Answered on Apr 19, 2019
cartidge cannot be recognized ma'am. try to change the color cartridge ma'am. by: cris
Canon Pixma... | Answered on Feb 23, 2019
eror usb.canon IP2770
Canon Pixma... | Answered on Dec 01, 2018
make sure the cartridge has ink in it then soak the cartridge into cool water for 15 mins then use tissue paper to fully dry the chips and the printhead
Canon Pixma... | Answered on Nov 26, 2018
Try installing the latest printer driver -
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Canon Pixma... | Answered on Jun 18, 2018
U have to download resetter file
http://imadeitthisway.blogspot.com/2010/09/canon-ip-2770-reseter.html
http://m4sjoysaja.blogspot.com/2010/08/how-to-reset-clear-counter-canon-ip.html
I hope its working
Canon Pixma... | Answered on Jun 04, 2018
Hi. I am almost sure that there is obstruction. Try this. Unplug the printer, turn it upside-down and shake it up and down . Maybe the foreign object comes out . If doesn't. Get technical support
Canon Pixma... | Answered on Feb 26, 2018
Canon Printer fix error 5b01
Canon Pixma... | Answered on Jul 26, 2017
Install online is unusual way to do. People usually will download the driver first via internet (online). After installer driver software have been downloaded, we can run the file for installation.
If the installation success,we can connect printer to PC via cable data and we can start to use your printer.
You can download the driver from here :
Download Driver Canon Pixma iP2770
or from here :
Canon PIXMA iP2770/ iP2772 Windows All
Hope this help, and if you feel helped RATE please !
Canon Pixma... | Answered on Aug 05, 2016
I know a website which is Committed to custom USB. http://www.customusbdisk.com/ Please open this and look for the products which you like.
Canon Pixma... | Answered on May 18, 2016
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on
That is what it's manual says , basicaly can be anything. It needs the eye of an experienced one. Sorry for not being able to help you elseways.
The link below covers most of canon printer errors :
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Canon Pixma... | Answered on Apr 12, 2016
Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Place the print head back in and lock the lever down.
6. Place all of the ink tanks back in the printer.
7. Close the cover and turn the printer off.
8. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
For more help visit cbrtechsolutions
Canon Pixma... | Answered on Nov 04, 2015
Canon Pixma iP2700 InkJet Photo Printer Logo
536 questions posted
Clive
Clive
old marine
old marine
Ekse
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
service error 5100 canon
  • Office Equipment & Supplies
