20 Most Recent
HEWLETT-PACKARD Photosmart Premium C309n AllInOne InkJet Printer Questions & Answers
Hp C309n blinking power light
The blinking light indicates there is a malfunction; such as paper jam, cartridge missing or ink cartridge caddy has a problem (ink on bottom, or dryed up, etc; caddy can be pulled out and cleaned), or something you were going to print was not printed due to low on ink, etc. It may show a number that you could contact H/P support, give them model of printer and the error number and they may be able to assist. Actually, blinking light could be a host of problems. Take cartridges out and carefully clean the brass contacts and also on the printer head, clean that too. Edwin, USN-Ret.
My printer will not print.
Hi there, regarding with the problem that you have..the error message that you are encountering with that machine is something about to work on with the printhead..because the printhead is the one causing the problem why is that the error message keeps on popping up, i believed that the printer model that you have is already out of warranty..the printhead is not replaceable if the printer is out of warranty.. well in that case, quite frankly the printer is already faulty.
you can definitely call HP by dialing this number 1-800-474-6836 and let them see what they can do in their end..
Thanks!
My hp photosmart c309n printer won't print
Click on printers&faxes(XP)
or
Devices & printers(7)
click on ADD A PRINTER
install basic driver i.e Deskjet 990c (xp,vista)
or deskjet 460 (7)
it will work great
i have tried this and it works
Hp laserjet 5100n
Go to the hp.com site and search for said driver. Sometimes they do not update their drivers for older machines, but I am not familiar with this one. Good luck. Once a year Staples will have a special where one can trade in an old machine for a discount on a new HP.
HP Laser printer USB connector broken
What model? Connector on the outside or on the mainboard? If on the mainboard, replace it. If on the front, you should be able to just replace the connector cable and/or mounting.
Cannot receive fax
make sure you have a phone line plugged in correctly (into the in plug) and set the printer / fax to recieve auto. Do not pick up the phone while recieving the fax, If thei does not work, check your setting in the software.
