20 Most Recent
LG WM2050CW 40 cu. ft. Washer Questions & Answers
Water leak from top drum area of washer
the top ring has small drain holes if blocked the water overflows the ring instaed of going into the bowl also if the machine is not level this can cause water to splash down the outside of the bowl
I have an LG WM2050CW washer and I cannot get it
Have you checked the selonoid valve? It's the piece that your hoses connect to. The part isn't that expensive when you compare it to a new machine. I changed one several years ago on a Whirlpool and I think it was around $15-20.
Water is coming out from the bottom
Water leaking out from the machine can be caused by a number of problems:
Check the drain pump hoses for condition and security, check the tub seals and also door seal.
Does not spin clothes very
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
I receive an error code
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
