20 Most Recent
Norcent Technologies PT4231 42 in. HD-Ready Plasma Television Questions & Answers
How do i connect netflix to my plasma monitor
probably not a good idea. plasma monitors have been quite a problem. when an image moves it will leave a some of its self still be behind and be in the way of the next image in motion. this will happen if the plasma monitor is on too long, because plasma is a type of liquid that has been known to over heat and burn into the screen. so im just giving you a heads up before you do it. the best screens to use are LCD screens, because unlike plasma and LED, it wont overheat and ruin the monitor
4/18/2013 4:24:40 AM •
Norcent...
Answered
on Apr 18, 2013
NORCENT MODEL PT4231.TURN THE MASTER
The continuous flashing indicates that the power source is in protected mode: another part inside the tv has failed, it draws an excessive amount of current and that has been detected by the safety system of the power source who has shut it down to protect it and the rest of the tv.
Since the status light goes to orange for a few moments before going red it means that the problem is outside the power source. The most probable cause is indeed with the mainboard; if it would have been one of the Sustain boards the failure would have been much more brutal and instantaneous (no orange on the status light) .
To certify that you will have to test the mainboard with an oscilloscope to find out if the processor is operational. If you don't have one just swap it.
2/15/2011 9:29:21 PM •
Norcent...
Answered
on Feb 15, 2011
2 inch line vertically down center of screen
You have a bad LCD driver that can only be fixed by replacing the LCD screen. Chances are the cost of the screen exceeds the cost of the TV, and if you're not under warranty I'd recommend a new unit.
1/19/2011 3:09:27 AM •
Norcent...
Answered
on Jan 19, 2011
Tv will not stay on
Hi
Thanks for using FixYa. From what
you have described it seems the issue is with the power board or the main board
we’ll need to check few things. When you open the unit up; take a look at the
power board-the board where, the power cords/plugs goes into. You might see
some filter capacitors a little bulged up in the top-If this is the case-this
is your defective part(you can try to replace them-but some soldering equipment
is needed). If not, then probably the main board has gone bad. This is the other
board-where all the inputs are going into. All this is only recommended if you
have electrical expertise and know how to solder/re-solder components. Please do accept the solution if
the issue is resolved or else revert for further assistance.
Thanks
Rylee
3/28/2010 2:34:43 PM •
Norcent...
Answered
on Mar 28, 2010
Green light comes on brifly
What is model number printed on back of TV?
Have you removed back and Looked on power supply board for Bad capacitors they will be swollen.vented or puffed up on top?
1000uf 16v 220uf 330uf 10v and does your set have cpu fan for cooling some have it some dont, if you do make sure it does not have dust or dirt on it.
3/28/2010 12:07:43 PM •
Norcent...
Answered
on Mar 28, 2010
Tv shuts off and on by itself
I only hope you have connected the tv with a stabilizer or is it inbuilt? This might be because of Voltage fluctutations. Also, check the connectivity of the internal power card.
Regards,
HP
8/29/2009 3:39:02 PM •
Norcent...
Answered
on Aug 29, 2009
A black single line about six inches from top
Take the TV Back....bad transformer in it, not worth fixing unless you're under warrantee or have extended service plan. Replace if you can as NORCENT is bottom rung of these types of TV's. If you don't know or haven't heard of them, don't buy them...from a guy who sells these things!
4/26/2009 7:40:37 PM •
Norcent...
Answered
on Apr 26, 2009
Screen problem
im afraid to tell you that your display has gone faulty there is nothig you can do apart from change the display contact the shop where you got your set from they should be able to help you.
3/10/2009 10:26:42 PM •
Norcent...
Answered
on Mar 10, 2009
My last question, I promise!
No on the contrary, most defective components on a defective board will malfunction when they reach operational temperature, and a chemical called component cooler is often employed to locate the faulty component. Semiconductors are weird as some malfunction when cold and work fine when warm, but the majority will fail when operating temperature is reached. If you need assistance please let me know.
6/26/2008 3:52:52 AM •
Norcent...
Answered
on Jun 26, 2008
Eske told me to ask you
Thats usually related to the control board being defective when its across the entire screen, But check the ribbon connections on the control board
6/25/2008 8:37:22 PM •
Norcent...
Answered
on Jun 25, 2008
Eske told me to ask you!
Are the vertical lines across the entire Screen? If so it could be the control Board. If the lines only go part way from the top but not all the way to the bottom. Depending on where they are it could be the x boards. can you post a picture of your screen with the lines?
6/25/2008 3:31:23 AM •
Norcent...
Answered
on Jun 25, 2008
Norcent Problem
I work in computers for the most part,
Please ask Slinteriors
http://www.fixya.com/users/slinteriors
Hes the TV guy to ask.
Please don't rate this solution, don't rate don't rate don't rate dont rate dont rate.
Thank you,
Ekse
6/24/2008 5:21:17 AM •
Norcent...
Answered
on Jun 24, 2008
No video
I had the same problem too. It called the Y-main Board. It cost $145 if you order directly from Norcent itself. I hope that help.
4/18/2008 4:37:49 PM •
Norcent...
Answered
on Apr 18, 2008
