20 Most Recent
FUJIFILM BC45W Rapid Travel Battery Charger Questions & Answers
Re: Battery Charger BC-45W
I just
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
WHEN PLUG IN BC-45W CHARGER
Scrape any dirt from the contats of both the battery and the charger.
Check the wires and plug for any loose connection.
If it charges normally apart from the light, then the fault is only with the light.
I just bought a Fujifilm Finepix HS10 and think that the Aperture doesn't work. When I turn the Aperture ring nothing Happens.
The Fujifilm Finepix HS10 camera features a manual aperture ring on the lens barrel. If you're experiencing issues with the aperture not functioning when you turn the ring, there are a few potential causes and troubleshooting steps you can try:
- Check the camera mode: Ensure that the camera is set to Manual (M) mode or Aperture Priority (A) mode. In these modes, you should have control over the aperture settings. If the camera is in a different mode, switch to M or A mode to enable manual aperture control.
- Enable aperture ring control: Some cameras have a setting that allows you to enable or disable the use of the aperture ring on the lens. Check the camera menu or settings to ensure that the aperture ring control is enabled. If it's disabled, enable it to regain control over the aperture.
- Ensure the lens is properly mounted: Check if the lens is securely mounted to the camera body. If the lens is not properly attached, it may result in the aperture ring not functioning. Remove the lens and then carefully reattach it, ensuring it clicks into place.
- Clean the electrical contacts: Dust or debris on the lens contacts or camera contacts can sometimes interfere with communication between the camera and lens. Use a clean, lint-free cloth to gently wipe the contacts on both the lens and camera body. This can help ensure proper electrical connections.
- Update the camera firmware: Visit the Fujifilm support website and check if there are any firmware updates available for your Finepix HS10 camera. Updating the camera's firmware can address potential bugs or issues that may affect the aperture functionality. Follow the instructions provided by Fujifilm to update the firmware if necessary.
If you have tried these troubleshooting steps and the aperture ring still does not function as expected, it is advisable to contact Fujifilm customer support or take the camera to an authorized service center for further assistance. They will have the expertise to diagnose the specific issue and provide appropriate solutions or repairs if needed.
Fujifilm fine pix camera won't turn on
Old batteries will take a charge, albeit more quickly and cannot supply enough power to carry on working.
Time to purchase a new battery and hope you won't need a new camera as well.
My Fujifilm Finepix S8000FD was unused for a long time and had its batteries leaked, I cleaned it and it says batteries are empty?
It takes 4 x AA batteries. Are the battery contacts on the compartment door, and the battery contacts in the base of the compartment clean and shiny. Usually when batteries leak, they cause oxidization on the metal.
The camera does have very specific requirements.
Batteries are required to operate the digital camera. At
first, load the batteries in the camera.
Compatible batteries
AA-size alkaline batteries (4) or AA-size Ni-MH
rechargeable batteries (4) (sold separately)
CAUTION
• Never use the following types of
batteries, as they could cause
serious problems such as battery
fluid leakage or overheating:
1. Batteries with split or peeling
outer casings
2. Combinations of different
types of batteries or new and used batteries together
• Do not use manganese, Ni-Cd or lithium batteries.
• Use the same brand and grade AA-size alkaline
batteries as those supplied with the camera.
https://www.manualslib.com/manual/54755/Fujifilm-Finepix-S8000fd.html?page=16#manual
And on the next page it shows the polarity two up, and two down. If those weren't correct, you would be on reduced power.
What's the problem and how to fix it fujifilm a100 10 mega pixel digital camera
Without more information about the specific problem you are experiencing with your Fujifilm A100 10 megapixel digital camera, it is difficult to provide a specific troubleshooting solution. Here are a few general tips that may help resolve common issues with digital cameras:
- Check the battery level and replace the batteries if they are low or depleted.
- Check the memory card for any errors or corruption. Try formatting the card or using a different card to see if that resolves the issue.
- Make sure that the camera is not in a mode that is preventing it from functioning properly (e.g., "Movie" mode when trying to take still photos).
- Check the camera lens for any dirt, dust, or debris that could be obstructing the image. Clean the lens with a microfiber cloth or compressed air if necessary.
- Check the camera's firmware version and make sure that it is up to date. If it is not, consider updating the firmware to the latest version.
