20 Most Recent Samsung SF-560 Plain Paper Laser Fax Questions & Answers
2answers
I need a driver
a samsung sf-560 can not print form a pc.
it must be sf-560P
drivers at www.samsung.com
3/15/2019 1:06:22 AM • Samsung SF-560... • Answered on Mar 15, 2019
The Samsung sf-560 is spitting the faxes etc. out of the back of the machine... how do I stop it from doing this and restore the output to the front tray?
The output cover in the back of the Samsung is most likely in the up position. When it is then all output will come out the back of the sf-560. To stop this from happening just close the back output cover by pushing it back down and closing the back cover. Then your output will come out the top shoot.
1/23/2015 4:55:30 AM • Samsung SF-560... • Answered on Jan 23, 2015
How i change the baud rate
why would you want to change the Baud rate? you don't need to do that.. Ive worked on faxes for over 30 years and never once have I changed a baud rate.. leave it alone.. I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
5/5/2014 5:44:00 AM • Samsung SF-560... • Answered on May 05, 2014
2answers
We have this fax machine in our office and it is
clean all the rollers which pickup paper.
5/3/2014 9:49:11 AM • Samsung SF-560... • Answered on May 03, 2014
MORE THAN ONE SHEET GOES THROUGH AT A TIME
clean all the rollers or if the fax has a separation pad replace it.. yes it does have a separation pad the part number is Samsung JC73-00140A you can purchase this item at Precision Roller for $10.00 I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
5/3/2014 9:43:25 AM • Samsung SF-560... • Answered on May 03, 2014
It says recieving but then it doesn't print
you may need to replace the toner I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
5/3/2014 9:36:52 AM • Samsung SF-560... • Answered on May 03, 2014
Cf-5100 cartridge fuse location
on the cartridge on the inboard(back of it) Use the right one (about 1.4 watt or less or it will mess up fax, why don't you buy a new 35 cartridge?
4/30/2014 12:22:45 AM • Samsung SF-560... • Answered on Apr 30, 2014
0answers
Paper feed not feeding properly
There is a gray rubber pad on the upper half of the feeder.
Take the white piece off and turn the pad 180 degrees.
11/6/2013 11:18:13 AM • Samsung SF-560... • Answered on Nov 06, 2013
4answers
Received fax's are not printing.
TYPICALLY A FAX MACHINE WILL RECEIVE MESSAGE IN MEMORY WHEN NO PAPER OR TONER/INK FINISHED INDICATION IS THERE, REPLENISH THESE SUPPLIES WITH GENUINE ONES AND FAX WILL START PRINTING. IF PROBLEM IS NOT SOLVED , PLEASE TRY TO CLEAR THE SETTING FOR MEMORY RECEIVING, IF STILL NOT SOLVED TRY BRINGING THE MACHINBE TO FACTROY SET SETTING BY CLEARING THE MEMORY. HAPPY FAXING OMNIPRESENT
2/15/2012 10:31:28 AM • Samsung SF-560... • Answered on Feb 15, 2012
Need to know how to
hold the 01 button in. releas it untel it shows t01. then put the details in and pres enter
12/15/2011 12:22:57 PM • Samsung SF-560... • Answered on Dec 15, 2011
LOW HEAT ERROR
There is a problem whit your fuser unit.
12/15/2011 12:20:34 PM • Samsung SF-560... • Answered on Dec 15, 2011
Hi we have a fax
press menu#1943menu again look for new cartridge it will print.you can maby shack the cartrige befor you do this.so that your prints can be better
12/15/2011 12:19:53 PM • Samsung SF-560... • Answered on Dec 15, 2011
Hi i have a Samsunf
you can not send it to your pc but you can reset you cartridge. press menu#1943menu again look for new cartridge it will print.you can maby shack the cartrige befor you do this.so that your prints can be better.
12/15/2011 12:18:11 PM • Samsung SF-560... • Answered on Dec 15, 2011
SF 560R receiving no electrical
you will see a 1500uf 25v cab wich is swelen. replace it on the power supply with 100uf or1500uf 35v
12/15/2011 12:13:34 PM • Samsung SF-560... • Answered on Dec 15, 2011
Samsung SF-560 Plain Paper Laser Fax Logo
130 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Office Equipment & Supplies
Most Popular Question
reset sumsung
  • Office Equipment & Supplies
