20 Most Recent
Ricoh FT5832 Copier Questions & Answers
C6 ERROR
C6: Cover open ,Close the ADF cover ( located in the upper cover right side )
Help me : Ricoh aficio
sc982 is usually an error with the NV-RAM (non-volatile RAM). Have you recently replaced the NV-RAM? If so, it probably just isn't sitting right on the board.
Have you tried turning the machine off (with the main power switch) and turning it back on? If the error reappears, you likely have a problem with your NV-RAM and it will need to be replaced.
Sorry for the bad news, but hopefully this information will help.
Copyer
This is a very old machine but the code indicates an exposure problem. a sensor is not dectecting the exposure lamp comeing on when it should. This can only be solved with a service call. Possible optics board problem or a bad connection from the exposure area to tne circuit board. Remove the back of the machine an ensure all connections coming from the lamp area are plugged in. remove and reinsert the connectors. You might get lucky and that is all it is.
Dave t
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Ricoh ft 4522
check the fuser first, it should be clean and shiny otherwise it's coming from drum area
E140 error
Lens vertical home position sensor error 1
- Definition - [B]
The lens vertical home position sensor remains de-actuated 3.0
seconds after the lens starts returning to the home position.
- Possible causes -
· Lens vertical home position sensor defective
· Lens vertical drive motor defective
· DC power supply board defective (check FU303)
