Access Procedure 2 - Using DPS101-2
1. Turn the main switch off.
2. Remove the BACK rear cover AND EXPOSE THE MAIN BOARD. LOCATE DIPSWITCH 101 ALSO CALLED DPS101 AND PUSH UP THE NUMBER 2 SLIDE OF THE 4 SLIDES and turning on DPS101-2, then turn on the main switch. "5" will blink in the Copy Counter.
3. Enter the desired SP mode number IN THIS CASE " 97 "by the numeral keys. SP mode
numbers are given in the Service Program Mode Table.
4. Press the Auto Image Density key to view the data. IN THIS CASE INPUT A "1" AND PRESS AUTO IMAGE DENSITY KEY TO CONFIRM AND ENTER THE "1"
5. To leave SP mode, turn off DPS101-2.
NOTE: To cancel an already entered SP mode, press the Auto Image
Density key.
76 questions posted
629 Questions
382 Questions
267 Questions
215 Questions
218 Questions
