20 Most Recent Mitsubishi WS-55807 TV Questions & Answers
2answers
TV off in 2 minutes
go into menus and disable timers.
7/28/2021 5:07:23 AM • Mitsubishi... • Answered on Jul 28, 2021
How to replace DLP chip
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage"
10/12/2016 1:12:30 PM • Mitsubishi... • Answered on Oct 12, 2016
2answers
Mitsubishi WS-55807 Error Code 24 Vertical Deflection Failure. 5.
Hi. The service manual is in more than one part. Schematics are in part 2 here: Download Service Manuals for free
8/1/2016 4:01:51 PM • Mitsubishi... • Answered on Aug 01, 2016
2answers
Stuck on Home Theatre Mode
Jack,
This Model Is Equipped With A Keyboard Lock Feature. To Unlock The Keyboard Press And Hold The "Menu" Button On The Front Panel For 10 Seconds. Then See If You Can Access That Menu Function.
Bill
7/6/2016 9:06:19 AM • Mitsubishi... • Answered on Jul 06, 2016
2answers
Tv screen
hi there, you have a power supply problem, check and dry up the damage are were the water goes and do some test at the power supply section first. ty
1/27/2015 3:44:29 PM • Mitsubishi... • Answered on Jan 27, 2015
No picture with blinking yellow light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
11/1/2014 1:36:59 AM • Mitsubishi... • Answered on Nov 01, 2014
Why does my tv go off frequently?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
8/31/2014 6:49:56 AM • Mitsubishi... • Answered on Aug 31, 2014
Picture is fuzzy for 3 - 5 minutes - then ok. what needs to be replaced?
nothing - if it is fine when it warms up, leave it alone
7/27/2014 10:54:56 PM • Mitsubishi... • Answered on Jul 27, 2014
White dots
if center dot yoke problem
4/29/2014 9:40:35 AM • Mitsubishi... • Answered on Apr 29, 2014
White dots on tv
Panel should be suspected. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
4/2/2014 7:35:41 AM • Mitsubishi... • Answered on Apr 02, 2014
Tv does not turn on
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts.
3/31/2014 3:40:55 AM • Mitsubishi... • Answered on Mar 31, 2014
0answers
2answers
I need the V-Chip code for an HD 1080 series TV.
delete characters by pressing cancel for each character
1/7/2014 7:20:04 PM • Mitsubishi... • Answered on Jan 07, 2014
Mitsubishi WS-55807 TV Logo
346 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi ws 55807 error code 24
  • Televison & Video
