20 Most Recent Mitsubishi CS-27205 TV Questions & Answers
Remote control code for Mitsubishi TV CS27205
028,022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/ http://electro-medical.blogspot.com/ http://electrohelponline.blogspot.com/ Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
2/14/2015 2:36:35 PM • Mitsubishi... • Answered on Feb 14, 2015
What has caused my viewing screen to shrink?
HI,. Try this link: http://www.eserviceinfo.com/ If the dimension has decreased vertically, surch for bad electrolytic capacitors in the vertical deflection circuit. Look for loose solderings on the pcb foorprints of the vertical final integrated circuit. Good luck
8/26/2014 3:08:15 PM • Mitsubishi... • Answered on Aug 26, 2014
I have tv a cs
Sounds like the picture tube is burnt out. It can happen when the television is left in direct sunlight. There is no cure for it, you can however put in a darker area and over time it may clear itself up.
5/25/2011 6:25:47 AM • Mitsubishi... • Answered on May 25, 2011
Lost remote and tv is stuck on parental code
Hello phillip and welcome to FixYa. A possible easy solution would be to power offf the television and unplug it. You should leave it unplugged for about 15 minutes. This Should remove the parental control screen and solve your problem. I hope this solution works out for you and good luck.
4/24/2011 3:16:48 AM • Mitsubishi... • Answered on Apr 24, 2011
My picture on my tv goes into to a vertical line
bad connections on vertical output ic
1/16/2011 4:31:25 PM • Mitsubishi... • Answered on Jan 16, 2011
Mitsubishi diamond vision 27" 1995
It is an indication of leaky electrolytic capacitor on the vertical section.
This is not a diy if you are not an expert.
I've adviced you to look for a qualified technician to replaced the faulty capacitor.
This is quite fixable and easy to locate by the technician.
pls rate my help...
Thanks for using fixya.
1/16/2011 4:25:47 PM • Mitsubishi... • Answered on Jan 16, 2011
Screen is dark, image barely seen. Sound is ok.
I suspect the bulb of your TV. When a TV bulb is weak, it make the screen dark. So, have you ever changed the bulb of your TV since you've started using it? I think its high time you replaced the bulb.
Good luck.
12/7/2010 9:46:01 AM • Mitsubishi... • Answered on Dec 07, 2010
I have a tv mitsubishi model cs 27205 the
CHECK RESISTORS ON CRT BOARD .THE BOARD IS MOUNTED AT THE BACK OF PICTURE TUBE .
8/12/2010 3:41:32 AM • Mitsubishi... • Answered on Aug 12, 2010
What is the
6/25/2009 3:35:12 AM • Mitsubishi... • Answered on Jun 25, 2009
Screen is black except for thin line in middle of screen
The problem is in the vertical section of the main board. Bad capacitors and maybe the vertical IC. If you are not inclined to be a tech you will have to take it to a shop.. I don't know what they may charge but I normally get $69- $89
4/10/2009 5:00:10 PM • Mitsubishi... • Answered on Apr 10, 2009
Single green line spanning across the screen horizontally
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
4/9/2009 12:49:44 AM • Mitsubishi... • Answered on Apr 09, 2009
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
2/21/2009 5:33:10 PM • Mitsubishi... • Answered on Feb 21, 2009
Dominant blue
Can you post to the party who has too much green how to adjust the video adjustments? They need to know so they can see if
its just a simple adjustment.
In your case, first turn the color level clear down to where you
have a black and white picture. As in the case of too much green,
question is if the picture is black and white or if there is a color
on the screen so its blue and white? I suspect it will be which
is typical when the guns start to fail. Likely the green and red
guns are weak in output. There are screen adjustments in the set that a tech can set up that may help some, but the only real fix is to replace the guns which is expensive and requires a complete allignment. All 3 guns need changing to get it back to spec and it is a good idea to replace the flyback for reliability. Get an estimate and likely you can replace the set for the same money.
2/21/2009 5:27:44 PM • Mitsubishi... • Answered on Feb 21, 2009
Our Mitsubishi TV is flashing a blue screen every 10-15 seconds?
Two questions for you.
1. What is the model of the set?
2. What sources are you trying to watch? Are you on cable, satelite, dvd player, vcr,
which of these are you watching and does the problem occur on all sources or just
certain ones?
Not having the above information, I will give you some information. Blue screen comes up
on these sets because of a loss of video signal. First thing you should do is to check your
cables between your sources to see if a wire has pulled partway or now completely out
say between satelite receiver and set. You might replace the cables in case you have
a broken wire inside the cable.
Some sets have the ability to go into the menu and shut off blue screen so you can
then see what the video looks like even if it is low level. From there you can do some
diagnostics by wiggling or connecting/ disconnecting the cables.
Beyond this there could be a loose connection internal to the set or a part failing, but
be sure to check for those cable connections first as that is the most likely cause. Also
it is good to try it with another video source or test the source on another set to be sure
that the video source hasn't developed a malfunction.
2/21/2009 4:43:59 PM • Mitsubishi... • Answered on Feb 21, 2009
How do I get closed caption on my TV?
Step thru video menu selections one at a time until CC comes
up, then change with plus or minus....can be done with remote
or at set............if more help needed, do we have the owner'
manual ?....................Please let me know....T.
12/8/2008 9:26:16 PM • Mitsubishi... • Answered on Dec 08, 2008
TV problem
Hello Barbara76,
Is this a Horizontal line (inch or two) across the screen, if so
the fault could be either a faulty Vertical IC,Faulty Electrolytic
capacitors or just simple dry joints.
Regards
Patrick
P-Tronics
2/3/2008 11:48:22 PM • Mitsubishi... • Answered on Feb 03, 2008
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
12/27/2007 7:02:20 PM • Mitsubishi... • Answered on Dec 27, 2007
Repost: some channels missing.
try going as high as the channel will go taking time to see if there is a picture on each change
12/27/2007 6:55:33 PM • Mitsubishi... • Answered on Dec 27, 2007
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
12/26/2007 12:46:40 PM • Mitsubishi... • Answered on Dec 26, 2007
Some channels missing...
Try to tune the tv in manual search method. If you get means store it manually. Nothing to worry. This is due to malfunction in AUTOMATIC FREQUENCY CONTROL COIL weak. Even you won"t get channels in manual tunning method. Change tuner and afc coil. Problem solved.
12/8/2007 7:04:31 AM • Mitsubishi... • Answered on Dec 08, 2007
Televison & Video Logo
Popular Tags
30 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi diamond vision 27 1995
  • Televison & Video
