20 Most Recent Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Questions & Answers
Best Settings for Picture Quality, Coloring, and Lighting
Factory setting. Do a reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
6/19/2017 9:12:41 AM • Mitsubishi... • Answered on Jun 19, 2017
Solid yellow lamp light AND flashing yellow status light
start with the lamp.
6/7/2016 10:10:17 PM • Mitsubishi... • Answered on Jun 07, 2016
Keeps blowing lamp
buy a flatscreen and consider it a down payment on 2 years worth of bulbs
7/29/2015 12:42:11 AM • Mitsubishi... • Answered on Jul 29, 2015
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010 Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life. https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
4/29/2015 7:43:59 AM • Mitsubishi... • Answered on Apr 29, 2015
2answers
WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
2/13/2014 3:00:21 AM • Mitsubishi... • Answered on Feb 13, 2014
Turn tv on heard a noise like glass breaking the
Check the lamp its most likely shattered.
1/25/2014 1:37:23 AM • Mitsubishi... • Answered on Jan 25, 2014
Mitsubishi wd-52327 tv no sound no picture but there is noise in the back
Have a look at the lamp first and the noise should be a fan.
9/3/2012 9:20:33 PM • Mitsubishi... • Answered on Sep 03, 2012
Mitsubishi wd-52327 no power, lights, nothing. Power board? What/how to test? Is it even worth fixing?
follow the power into the set and to the power supply, a lot of these had puffed up caps on the power board kill the whole set-----You will not find it a real easy set to get into or open up8_28_2012_1_08_37_pm.jpg8_28_2012_1_09_00_pm.jpg
8/28/2012 1:09:49 PM • Mitsubishi... • Answered on Aug 28, 2012
Mitusbishi WD-52327 tv cannot figure out how to get the digital cable box to come on screen?
Connect RCA wires (yellow, red, white) from the box's "out" to the tv's Input 1 or 2 on the back input panel of the tv set. If you don't have RCA's you may use a RGA- jumper wire (cable wire made into a 4 ft segment by the tech or buy a short cable wire from the Walmart, Target, or Goodwill store) Connect this wire to the "cable in" on the tv and the other end to the "cable out" on the box.ADDITIONALLY make sure you have the right input settings selected on the tv with the input selection you make with the wire connection you choose.
6/21/2012 5:28:44 PM • Mitsubishi... • Answered on Jun 21, 2012
Mitsubishi tv will turn off
The set should have lights on the front that blink when it does this--Lamp is possiblelamp Ballast is possible The set also has a error buffer that can be called up if shuts off--blink code on front of set.Another common issue is set will play for a while and shut off--which best describes your problem?
5/27/2012 11:35:17 PM • Mitsubishi... • Answered on May 27, 2012
No picture on screen but there is sound
when you tune in a tv station or playing a dvd player. if you playing a dvd player maybe your vido cable is not fully insert the plug (yellow color) . The red and black/white are for the audio.
4/18/2012 8:22:39 AM • Mitsubishi... • Answered on Apr 18, 2012
Mitsubishi WD-52327 52" Rear Projection HDTV-Ready Television Logo
142 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
replaced lamp
  • Televison & Video
