20 Most Recent
Mitsubishi VS-50111 50" Rear Projection Television Questions & Answers
Unit turns on for a few seconds then turns off
Usually in these sets the 2-2 error code is a shorted convergence IC----they are protected in most models (don't know your exact model number) by two pico fuses(they do not look like glass fuses and are usually in the power supply--little green parts that look like small resistor--amperage is marked on them and usually they are 5 amp) the fuses can be checked like any other type of fuse---if one or both of these are open the set will detect no voltage to the convergence chips and shut the set down. If you locate the convergence chips look for any discolored or burnt resistors around them----in most models they are light blue in color and marked 3.9 ohms---if any are white in the middle they are gone---
I do this here for free so if this helps you give me a vote here.
if you need direct help:
[email protected]
Overscan
Yes, if you have the original remote and get into the adjustment menu which is hidden you can adjust width, height, and centering if you want.
12/10/2012 12:48:52 AM •
Mitsubishi...
Answered
on Dec 10, 2012
Can not turn off the vchip channel lock on hd 1080
hello try this
Bypassing the V-Chip Lock
After you set the lock, you need your
passcode to view a V-Chip locked program,
view the locked TV, cancel the lock, or enter
the V-Chip lock menus.
If you forget your passcode, you can
view the locked TV without entering your
passcode. This is done by pressing the
number 9 and QV buttons on the remote
TV control at the same time, when your
password is requested. This process
temporarily unlocks the TV.
When entering the V-Chip Lock menu, this
process deletes your old passcode and
prompts you to enter a new passcode. good luck
regards
shaun
