20 Most Recent
Toro Super Recycler Super Bagger Lawn Mower Rear Bagger 5 Questions & Answers
Toro lawn mower won't start
3 most common possibilities: Most gas mower carburetors have a tiny hole for the fuel to rise into the vacuum venturi throat of the intake. The hole in this riser tube which goes down the center of your float chamber to the area where the fuel sits in the bowl is only about as big as dental floss. Take the tine of a wire brush to clear it of crystallized or varnished gasoline and oxidized pot metal tube crust. When they make stainless carburetors, it will eliminate half of the heart attacks caused by this problem. Additives and condensation that settle out in old gas also can lead to clogging. Another very common problem is shearing the aluminum alignment pin in the top of the crankshaft when the mower whacks a log, root or rock. The inertia splits the alignment pin in half and throws spark timing off. So it backfires or won't run. Also check your spark by grounding the fat end of the sparkplug with a jumper cable to the engine casing, leave it plugged to the wire and pull the cord to see if it is firing. Keep spark away from fuel. Ignition points in some small engines get crusty when sitting in humid conditions. So they have to be filed clean of oxidation for proper contact and sparkplug operation. Small engines like rich mixtures and starting fluid when they are cold.
PTO wont engage how can you check
www.
mowersdirect.com/
manuals/20382OM.pdf
Super Recycler® Lawn Mower. Model No. ... Whenever you need service, genuineToro parts, ... This manual identifies potential hazards and has safety.
You can download the above from google.
You can also check if there is a safety feature keeping the PTO from engaging.
Mower hit a rock and won't start
On most push mowers, there is a "key" that is located on the end of the crankshaft, opposite end of the blade, that drives the flywheel. It's a small rectangle piece of metal that connects the two. When the inertia of the blade stops abruptly, the flywheel acts as a safety for the engine, and shears the key. Tools are made to remove the flywheel and videos online for repair assistance. Replacement keys are specific to the engine you are working on. Hope this helps!
Toro lawnmower Wiil not start
Remove carb float bowl. Clean bowl. Observe float bowl screw, look for hole thru bolt, if present use thin wire to clean out. Float should be hanging freely and gas should be flowing, raise float gas should stop. Pinch off gas line or use shut off valve. Remove pin from float, remove float and needle meter. Use thin wire to clean out passage were meter needle is inserted, wire should pass thru to behind choke. Replace float & meter needle. Replace float bowl. Pull rope half way several times. Inspect primer bulb for cracks or leak. Try to start, may take 5 or more pulls to prime.
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
I have a toro gts 6.5hp model 20017. The enginer
The way i set the govenor is, slacken the screw on the engine govenor arm, push the arm fully over to open the throttle wide open, now turn the actual govenor shaft within the arm in the same direction, fully retighten the govenor arm screw,
