20 Most Recent
Mitsubishi VS-6055 60" Rear Projection Television Questions & Answers
Tv shuts itself down
This is due to bad caps read here what a cap is
www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
TV works fine for 12-18 hrs. Then picture goes off
It seems that your unit has some sort of Thernmal problem or a problem that is shutting down the Power Supply section to the Video side of things.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Focus
Is the a mitsubishi or hitachi tv?
VS-6051 fuzzy picture
Those three Knobs were the focus or screen controls . your problem may be dust and dirt on the lens or the tubes could be getting soft. It could also be a convergence trouble and thats very common in these sets . a picture would be nice see where your problem lies BUT let me warm you down there where you were plying and turning those little knobs is about 32000 volts!!did you know this ? A tv set is not something to experiment with as it could kill ya. Unless you have technical background in electronics I would call a servicer to assist you. Good Luck
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options:
Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon.
Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
