20 Most Recent Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tractor Questions & Answers
I have a Craftsman DYT 4000 riding mower. The
I dont know that model but i had a similasr pronblem and i had to adjust the rod that ran from the shifter lever to the transmission
12/30/2017 4:01:39 PM • Craftsman YT... • Answered on Dec 30, 2017
2answers
Try start after sitting for about 1 yr . try to
sounds like you have a stuck valve or out of adjustment
3/16/2015 10:37:27 AM • Craftsman YT... • Answered on Mar 16, 2015
YT 4000 mower gradually lost forward motion during
I hate to be the bearer of bad news but it sounds like your transmission or rear end has went bad
9/20/2013 9:44:23 PM • Craftsman YT... • Answered on Sep 20, 2013
Lawn tractor will not engage in foward or reverse craftsmen
Call the dealer or look online.
8/12/2012 8:50:43 PM • Craftsman YT... • Answered on Aug 12, 2012
2answers
I find the steering linkage (all aspects) very
Many of these tractors have a very cheap gear and notched plate design for the steering....not exactly a recipe for tight steering...and also not something easily adjusted....just a very inexpensive way to do it!!
As for the plowing... that also is the result of poor and cheap design...the axle is solid and there os no differential so both tires try to turn together... thus the plowing...
I would not be happy either, but the Sears product is not exactly a "quality" product anymore...
If you are not happy with it...return it, cause it will never come up to your standards...
heatman101
9/11/2011 4:32:49 PM • Craftsman YT... • Answered on Sep 11, 2011
My craftsman riding tractor keeps blowing the fuse
I would try tracing the entire wiring to see if any are exposed and are touching metal.
7/15/2010 5:12:14 AM • Craftsman YT... • Answered on Jul 15, 2010
Does anyone know the length of a craftsman part number 66054 link arm.
The Craftsman part number 66054 corresponds to a link arm, but without specific details or access to Craftsman's database, it's challenging to provide the exact length of this part. To find the precise length of the link arm with part number 66054, I recommend checking the product description or reaching out to Craftsman directly through their customer support or website. They should be able to provide you with the accurate information you need.
4/3/2024 12:56:29 PM • Craftsman Garden • Answered on Apr 03, 2024
Craftsman Riding Lawn Mower 17.5hp. Why Engine Turns Slow, Starter Hanging Up, Won't Turn Over?
Hi Joe Still having trouble with that old mower! I thought you fixed it? You stated the reason it was turning over and lock up the mower had the wrong starter on it the Starter Motor Drive Bendix had 16 teeth and the mower needed a Starter with 14 teeth so I changed the Starter out. That's what I did. I reckon you are using batteries that are wearing out and don't have the required amps. Jump start the mower using your Santa Fe with the engine running. Or take the batteries to an Interstate Battery shop and ask them to test them. That is free, but they can also pulse charge them to desulphate the plates. There is a small charge for that and they keep the battery for 24 hours. Other things you can try. Remove the starter and connect it direct to the battery. See if it spins freely? Turn the engine over by hand to see if there is stiffness. Then do it with the plugs out. ..
3/11/2024 10:23:57 PM • Craftsman Garden • Answered on Mar 11, 2024
Craftsman weed eater, gas 25cc. How to replace the string line on it please?
Operator's Manual - CRAFTSMAN
Sears https://i.sears.com > mp-tc > prod_1977954512 PDF WEEDWACKER GAS TRIMMER. R. Model No. 316.711192 ... 25 cc (1.52 cu. in.) 0.025 in. (0.635 mm) ... Always use the fresh fuel mix explained in your operator's manual.
Sears https://i.sears.com > mp-tc > prod_1977959112 PDF Operator's Manual. CRAFTSMAN. 2-Cycle. WEEDWACKER GAS TRIMMER. Model No. 316.711471. INCREDI-PULLMW/TH. UNBELIEVABLE STARTING EASEâ„¢. CAUTION: Before using this ...
Instruction Manual
Sears PartsDirect https://c.searspartsdirect.com > doc PDF Jan 10, 2005 - For one year from the date of purchase, when this Craftsman DGas Powered. Weedwacker. Line Trimmer is maintained, lubricated, and tuned up ...
User manual Craftsman CMXGTAMD25SC (English
Manua.ls https://www.manua.ls > not categorized > Craftsman Manual. View the manual for the Craftsman CMXGTAMD25SC here, for free. This manual comes under the category not categorized and has been rated by 3 people ...
Operator's Manual
Sears PartsDirect https://c.searspartsdirect.com > doc PDF Operator's Manual. M. 4-Cycle. WEEDWACKER® GAS TRIMMER. Model No. 316.794490. CAUTION: Before using this product, read this manual and follow all its Safety.
Craftsman WEEDWACKER 358.791520 Instruction Manual
ManualsLib https://www.manualslib.com > manual > Craftsman-We... View and Download Craftsman WEEDWACKER 358.791520 instruction manual online. 25cc/1.5 cu.in. 2-Cycle 17 Inch Cutting Path / 0.080 In. Line GASOLINE ...
Craftsman WEEDWACKER C944.514460 Instruction Manual
ManualsLib https://www.manualslib.com > manual > Craftsman-We... View and Download Craftsman WEEDWACKER C944.514460 instruction manual online. 25cc / 1.5 cu.in. 2-Cycle 17 Inch Cutting Path / 0.080 In. Line GASOLINE ...
3/10/2024 4:11:39 PM • Craftsman Garden • Answered on Mar 10, 2024
Craftsman GT3000 garden tractor lawn mower. Why is my clutch not engaging on my tractor?
Check to see if the drive belt has snapped or come off the pulleys? https://www.google.com/search?q=craftsman+gt3000+drive+belt ..
3/10/2024 4:07:41 PM • Craftsman Garden • Answered on Mar 10, 2024
Why does the engine turn over and stop like the battery or starter is bad? How do I adjust the valves on a Craftsman riding mower 17.5 HP engine?
Hello Joe How old is the battery? Battery life in mowers is bad because they usually aren't well looked after in the winter, 6 months use and 6 months neglect. Also fuel is often left in the tank and in the carb which goes funky. Do you have a compression tester? Valve adjustment https://www.google.com/search?q=craftsman+riding+mower+17.5+adjust+valve+clearance ..
3/1/2024 2:07:15 AM • Craftsman Garden • Answered on Mar 01, 2024
How do I get to the ender real of my Weedwhacker when I can't even get the bolt to come off?
here is link to manual copy and paste https://www.searspartsdirect.com/manual/4v0ctntnsv-000247/craftsman-316711370-gas-line-trimmer-parts
2/19/2024 9:52:31 PM • Craftsman Garden • Answered on Feb 19, 2024
I have a craftsman ws 2400 2-cycle 27cc weed eater and the pull rope to start it broke . How do I fix it?
Video links at the bottom of this feedback. Turn Off the Ignition: Move the ignition switch on the Craftsman trimmer into the "Off" position. Remove the Starter Assembly Cover: Use a screwdriver to unscrew the starter assembly cover and remove it from the trimmer. Prepare the New Pull Cord: Cut off the old cord from both the pulley and the starter handle. Dispose of the old cord. Replace the Pull Cord: Flip the starter cover over and replace the pull cord. Make sure it's securely attached to the pulley. Reassemble the Starter Assembly: Put the starter assembly cover back in place and secure it with the screws. How to Replace the Pull Cord on a Craftsman Weed Trimmer (youtube.com) WS 2400 (CMXGTAMDSS27) (41ADSS27793) - Craftsman String Trimmer Parts Lookup with Diagrams ' PartsTree
2/15/2024 9:32:42 PM • Craftsman Garden • Answered on Feb 15, 2024
Repairing a craftsman ws 2400 2-cycle weed eater 27cc pull rope
This u tube video may help you https://www.youtube.com/watch?v=G9NM2V27WvY
2/15/2024 7:21:15 PM • Craftsman Garden • Answered on Feb 15, 2024
Craftsman YT 4000 42" Briggs Stratton 24 hp Gas Powered Riding Lawn Tractor Logo
Popular Tags
24 questions posted
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
find steering linkage all aspects very
  • Garden
