20 Most Recent Mitsubishi VS-50609 50" Rear Projection Television Questions & Answers
You may have accidentally set it to the demo mode.
The user's guide might help:
Mitsubishi VS 45609 VS 50609 User Guide
Mitsubishi... | Answered on Sep 06, 2014
Probably has lost convergence chips and fuses. But keep in mind--these sets often get a LOT of capacitor problems and fulid leakage problems too--so be aware of this.
Mitsubishi... | Answered on May 08, 2014
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mitsubishi... | Answered on Feb 23, 2014
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Mitsubishi... | Answered on Dec 19, 2013
Yes, you can play DVD movies on TV, you need the tuner if you want to see broadcasted channels.Your universal remote should have codes for Mitsubishi Rear Proj. Tv's. If you dont have the instructions with the remote , call the manuf. Good luck!
Mitsubishi... | Answered on Nov 14, 2013
when you take the front screen off the screen maybe dusty or the projecters are bad or the oil is burned. when you open them if theres a brown film over them the fluid is burned. the tv is not worth the cast of them or the fluid
Mitsubishi... | Answered on Nov 13, 2013
I think your in SAP mode.....couldn't unstand a word your saying.
Mitsubishi... | Answered on Aug 27, 2013
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mitsubishi... | Answered on Apr 10, 2013
ts will go into shutdown when a vertical issue is present but the audio will still continue to operate normally.
Mitsubishi... | Answered on Apr 02, 2013
you are going to need a ohm meter and they will be low value resistors--color bands denote the value and they have to be tested, do not think its possible for me to tell you which to replace as I would check them to know which.
You might find the service manual with Google for free at scribed.
Mitsubishi... | Answered on Nov 07, 2012
Either a bad solder connection in the Convergence circuit or the chip/s used need to be replaced.
Mitsubishi... | Answered on Jun 26, 2012
Its a one piece screwed and glued cabinet that cannot be taken apart.
Mitsubishi... | Answered on May 31, 2012
To get an idea of why the set is shutting down when it does shut down if power light goes out do the self check this set should have.
Does the power light go out when it fails?
Mitsubishi... | Answered on Apr 23, 2012
Sounds like you may have a bad convergance ic.
Mitsubishi... | Answered on Feb 29, 2012
Sir try to reset the lamp timer. you should press the "display" button on the remote then "5" then the "volume up key" and power "on" you should do this while the tv is in standby mode. Then press "Jump" 3 times to enter the DE service menu. Your tv will display the total lamp hours. Reset the lamp time by pressing channel 3, then mute, then enter. this will make your lamp hour timer to zero. Good day and best regards.
Mitsubishi... | Answered on Aug 21, 2011
Mitsubishi VS-50609 50" Rear Projection Television Logo
112 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
fuzzy picture
  • Televison & Video
