20 Most Recent Husqvarna 28cc Hand Held Blower HVH 125B Questions & Answers
My wife was using lawn blower, after about 15 mins it cut off. she checked fuel, tried to start again and nothng. waited 10 mins tried again nothing. I checked gas/air filter etc. all o.k., no sign of
Remove plug, leave plug wire on plug wrap a piece of conducting wire around the plug base and other end of wire wrap around metal part of engine pull starter and see if you have spark. You may have to darken area to see spark. If you have no spark probably bad coil or could be just switch has gone bad.
8/9/2017 2:55:42 AM • Husqvarna 28cc... • Answered on Aug 09, 2017
3answers
I messed up and took all fuel lines off from
try these sites, first, the exploded view part diagram for ordering parts http://weborder.husqvarna.com/order_static/doc/HIUS/HIUS2008/HIUS2008_545103429.pdf
second, (if this is not the right manual) then try this to find it, http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=&types=O,I
good luck!!
6/19/2016 11:36:20 PM • Husqvarna 28cc... • Answered on Jun 19, 2016
Where can I get a fuel line routing diagram?
Just go from the fuel tank straight to the carb and the primer. The pipes are a set length so you don't have to worry about threading it all around the blower.. just take the most direct route from the tank to the carb..!
4/22/2016 6:36:06 PM • Husqvarna 28cc... • Answered on Apr 22, 2016
Wont draw a prim
check primer bulb for cracks and leaks . check hose into the fuel tank for cracks and leaks pull the carby apart and replace stiff diaphragms.
7/24/2015 1:01:40 AM • Husqvarna 28cc... • Answered on Jul 24, 2015
Husqvarna problems
look for bad safty switch
9/17/2014 7:54:18 AM • Husqvarna 28cc... • Answered on Sep 17, 2014
What screw is L & H on husqvarna leaf blower 125b ?
unit is running lean. The lo is closest to the crankcase. Give the lo a half turn out.
9/1/2014 4:53:02 PM • Husqvarna 28cc... • Answered on Sep 01, 2014
Spark is not strong enough to arc across spark plug
I use the back of a pack of matches an that worked but I don't know what the gap of that is but worked on my chain saw!
8/24/2014 3:45:12 AM • Husqvarna 28cc... • Answered on Aug 24, 2014
Can you put a supply line back on that has come off inside fuel tank with fuel filter
The fuel line should be replaced
7/28/2014 1:03:03 AM • Husqvarna 28cc... • Answered on Jul 28, 2014
Gas is leaking from husqvarna 125B blower when priming
Either the return line to the tank from the primer has a hole in it, is broke, disconnected; or the diaphragms in the carb are stiff and the unit is flooding
7/27/2014 11:15:27 PM • Husqvarna 28cc... • Answered on Jul 27, 2014
New Husqvarna 125B blower runs fine then stalls
Is the gas fresh or old that you used. Since this brand new, it's under warranty. If you've had it for a few days, return to the store from which purchased it. It should run right out of the box without having to work on it.
5/17/2014 4:05:04 AM • Husqvarna 28cc... • Answered on May 17, 2014
Husqvarna 125b leaf blower
Have you checked the Flame Arrester in the Muffler. They clog easy and engine can't push out exhaust.
11/28/2013 10:37:27 PM • Husqvarna 28cc... • Answered on Nov 28, 2013
How to replace a primer bulb
should be pretty easy, four screws lift retainer clean & replace with new bulb.
10/14/2013 5:41:27 PM • Husqvarna 28cc... • Answered on Oct 14, 2013
Husqvarna 28cc Hand Held Blower HVH 125B Logo
75 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
screw l amp h husqvarna leaf blower
  • Garden
