20 Most Recent Samsung S5620 Cell Phone Questions & Answers
If you are trying to use a SIM card in your phone and getting a message like "Enter Subsidy Code", "Incorrect SIM Card", "SIM not provisioned" or similar messages, then you need an unlock code for your mobile phone. You can get Samsung S5620 Unlock Code from the network provider, they will verify the account holder information. They can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any network worldwide without sticking to one network. You can check Samsung Unlock Code site, they will provide you an accurate code fast with easy to follow instructions on how to unlock your phone, for the lowest price.
Hope it helps.
Thanks.
Samsung S5620... | Answered on Nov 07, 2019
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
Samsung S5620... | Answered on Nov 05, 2019
samsung sgh-e 700reset telefon pasword
Samsung S5620... | Answered on Oct 22, 2019
You need to Unfreeze the Samsung S5620 model mobile phone,You can get the Unfreeze Code at here
http://www.prounlocking.com/samsung-s5620-monte/rs8wp9/ and unfreeze it.
Samsung S5620... | Answered on Sep 26, 2019
If it Network Locked means.... You can get the Unlock code here http://www.theunlockarena.com/samsung-s5620-monte/rs13wp9/ and Unlock it.You check code for Your Network..
Samsung S5620... | Answered on Sep 19, 2019
Bypass Lock Screen on Samsung Galaxy without Data Loss
Android Lock Screen Removal & Data Recovery is a famous tool for removing password on Android lock screen without data loss. With the help of this program, you could bypass pattern/password on Samsung Galaxy lock screen without losing data.
Android Lock Screen Removal supports to remove 4 lock screen types on Android - pattern, PIN, password & fingerprints. Simple and easy to use. Android Lock Screen Removal works for Samsung Galaxy S/Note/Tab series, including Samsung Galaxy S9/S8/S7, Samsung Galaxy S6.
LEARN MORE Broken Android Data Extraction How to retrieve important photos from broken black screen Android devices How to Recover Data on Android with Cracked Screen How to Unlock Android Phone with Broken Screen
Samsung S5620... | Answered on Mar 20, 2019
Please check on the Samsung support site noted below for your requirement:
http://www.samsung.com/uk/support/download/supportGlobalDownloadPrdDetail.do
Samsung S5620... | Answered on Mar 18, 2019
no buddy samsung phones comes with some themes by company but u can't download any theme by anysite becoz i m also using samsung monte....
Samsung S5620... | Answered on Mar 13, 2019
I also experienced the same problem with my Samsung F480v. Samsung studios are not stable for all samsung phones. Some could work for a selected brand, unlike nokia. I suggest you follow this link, and download Samsung PC Studio 7 : http://www.brothersoft.com/downloads/samsung-pc-studio.html
Download it and install. Hope this helped.
Samsung S5620... | Answered on Dec 18, 2018
Samsung describes the operating system for the Monte as Propriety, which means that the OS can only be updated once Samsung itself releases new OS versions applicable for Monte, hence the installing of flash can not be used for changing or updating Monte's OS. This might be inclined with the marketing strategy that Samsung have, they might have plans releasing new phones with the desired OS that Samsung fanatics might be looking for.
Samsung S5620... | Answered on Nov 13, 2018
why whatsapp is not instaled in samsung s5620
Samsung S5620... | Answered on Oct 26, 2018
You Can Unlock Your Samsung . Call Your Network Provider To Ask Your Samsung Unlock Code. But your Network Provider Takes Time To Give You Unlock Code.
If You Want Your Imei Unlock Code Instantly. Buy Samsung Imei Unlock Code From Third Party. Many Site Available Online To Provide Imei Unlock Code.
I Hope This Will Help You.
Thank's
Samsung S5620... | Answered on Sep 24, 2018
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Samsung S5620... | Answered on Sep 19, 2018
You can hard rest your samsung S5620, but remember you will lose all your contact, messages, phone book etc.
- turn OFF the mobile - remove the sim card from the mobile. - turn ON the mobile and wait for the home screen to appear - now enter *2767*3855# wait for the phone to reboot. - Upgrade Monte firmware by downloading Samsung Kies and PC Sync.
Hope this helps,
Samsung S5620... | Answered on Aug 17, 2018
when you got the call there will be opction in your phone to record the voice..
Samsung S5620... | Answered on Aug 14, 2017
From Phone menu to contacts or address book then
1. Go the reject list on your phone
2. Just highlight the contact through keys which you want to be removed
3. Select options for that highlighted contact ans select remove from the list.
Samsung S5620... | Answered on Dec 21, 2016
Hi gag395,
One of the solution for slow mobile is to delete all your Txt messages in your phone, this should Significantly speed up your phone.
( save the important messages if you do not want to delete all )
I hope this helps.
Samsung S5620... | Answered on Dec 06, 2016
I am using Samsung Monte.How do i block a number from sending me messages for a perticular period?
How do i un-block it again?
Samsung S5620... | Answered on Nov 03, 2016
go to your carriers store ask them track where it is now, they can track the usage then you can deactivate it and shut id down to prevent any personal data from getting lost then you can get help to retrieve the phone
Samsung S5620... | Answered on Sep 07, 2016
Did you not use anything like Samsung Kies to back these things up before doing the reset? Or did you not have them syncing to your google account?
Samsung S5620... | Answered on Apr 17, 2016
Samsung S5620 Cell Phone Logo
807 questions posted
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Samsung Cell Phones
  • Samsung Cell Phones
Most Popular Question
want unlock code asphalt 6
  • Cell Phones
