20 Most Recent
LG 32LD450 32 In. LCD HDTV Questions & Answers
Where is the IR sensor in the LG lcd tv?
Mine is a question mine is a question my cat peed on my sensor on front of my RC a LG TV how do I replace the sensor the remote still works I've been turning it on and off manually it works with functioning it manually on the television
Cracked screen on lg lcd tv small crack 6in up an
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations
. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (
Exclude the model number), in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts
Tesco technika tv problems
How many times this power light flashes at one time switch on? Count it. These flashes are fault indications, and are called blinking codes. From the number of flashes occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV.
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.Blinking codes to many brand TVs are given in detail.
