20 Most Recent Sharp LC60LE810UN 60 in. LCD TV Questions & Answers
0answers
WILL A LCD CONTROLLER NOT FIRE THE BACKLIGHT
The LCD controller or T-con board does not control the back light. Some back light ballasts are incorporated into the power supply or the main board. Others are on their own board
9/12/2016 5:27:09 AM • Sharp... • Answered on Sep 12, 2016
Sharp aquos no power buttons on set
No. the power button on the TV will turn it on, change the channels and the volume.
9/12/2016 5:06:40 AM • Sharp... • Answered on Sep 12, 2016
0answers
0answers
0answers
How to replace the burned led light in my Sharp Aquos LC52LE810UN?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
3/9/2014 12:46:48 PM • Sharp... • Answered on Mar 09, 2014
Tv turns on but backlight fails to light up,
Have to make sure all ribbons are seated, and tabs locked. If any.
2/15/2014 12:40:20 AM • Sharp... • Answered on Feb 15, 2014
0answers
The on/off light on the bottom middle screen is blinking one solid time and then one fast time. The tv wont come on with the panel or remote.
POWER LIGHT FLASHES ONE SHORT AND ONE LONG FLASH. What is the problem? THE PROBLEM IS THAT ONE OF THE LED's STRIPS IS BAD! SHARP AQUOS LC60LE810UN RESET INSTRUCTIONS 1)Plug in TV to electric current First then wait until LED start flashing. 2)Press Volume DOWN HOLD ALL three buttons until LED stops flashing and then release. ·This will reset the TV in order to fix the problem. ·THE FIX IS TO REPLACE ONE OF THE LED's. You need to open the back of the TV and you will also need to remove the front cover and panel to get to the LEDs. The TV will need to be placed facedown and on the backside. This is a 2 person job to turn the TV on its sides. Be careful with the white computer connectors (wide white strip) at the base of the TV where the TV stand sits. You will need to disconnect this in order to get to the LED's. Once you have the LED's exposed, you will need to unplug one by one by placing the new strip next to it until the unit turns on. You will have to use the RESET procedure above if the Power lite flashes. The Power lite MUST BE ON SOLID - no blinking in order to test the strips. The LED's will flash, but still one of them will be burned. Even if you stare and all the strip light-up, you will still need to check one-by-one! Once the TV lights up, your face will also light up with joy! Put everything back together and you are set. If you need the complete instructions which come from Sharp as to how to disassemble the unit, please send me an e-mail to [email protected]. Please note I don't check this address daily, so a few days wait may take for you to receive the instructions. Where can you buy the LED's - try searchingSharp LCD/LED parts web site - Copy this link:http://www.encompassparts.com/item/8459814/SHARP/RUNTK4459TPZZ/LEDPWBUNIT(LC-60LE810UN),_X4 Yahoo.com or Google.com for resellers. SHARP AQUOS LC60LE810UN LCD STRIP INFORMATION LONG STRIP (49 LED's) FRONT SIDE BACK SIDE RL 94v-0 E329419 1029 LFa Sn-Ag-Cu Ps-1 K4458TP 4458ZZ 0921FM 104863 ee03A SHORT STRIP (30 LED's) FRONT SIDE BACK SIDE RL 94v-0 E329419 1025 LFa Sn-Ag-Cu Ps-1 K4459TP 4459ZZ 0714FM 302213 Mm05A
12/11/2013 4:43:40 AM • Sharp... • Answered on Dec 11, 2013
Sharp LC60LE810UN 60 in. LCD TV Logo
64 questions posted
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LC Sharp
  • LC Sharp
Most Popular Question
60 sharp aquos power indicator flashing
  • Televison & Video
