20 Most Recent
LG M2362D 23 in. LCD TV Questions & Answers
Sound but no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
TV wont turn on
If I understand you correctly u can occasionally get the tv out of standby using the remote but seldomly if ever using the tv mounted controls . This being the case I would suggest the capacitors on the output stage of your TVs power supply and starting to fail giving you low voltage and keeping the set in standby its a very comin fault on SMPS's
Flickering screen on lg m2362d
If you can hear sound, then screen is gone.I'll bet you don't.If you see an image, hear sound, just won't hold.I'd bet on the T-Con board.Not knowing what is really happening here..If willing to dive into electronic's.Open her up and start testing power side, starting with capacitors.
Hi..i have LG FLATRON TV.model
I got the same problem and i raged a lot ! But now it's better, so you should take your telecomand ant try all buttons and it will turn on again ( sorry for my bad english i'm french and i'm 14 ) yours faithfuly ;)
M2362D
try to replace sound board or sound IC
Hi I just bought a
The tv have a long board that called the tv LCD inverter board,this tv LCD inverter board only job are to control and help the all the amount of the tv LCD screen panel backlight brightness for the tv LCD screen panel for light.This long LCD inverter is the causes and the problems.New tv exchange it for another one,not so new take ur tv warrenty repair qickly the tv long LCD inverter board it is the causes an the problems must have to be change.
My LG M2362D keeps turning
Check the monitor cord to the PC, tighten them as also check the mother board for any loose connections. If possible try with an another monitor to confirm that the fault is with the monitor or not. If so open the monitor after disconnection of mains and solder all the suspected joints , seen to look dry. Check for loose components, capacitors, IC or resistor that detach the soldering connection when it is hot.
