20 Most Recent Pentax Optio 450 Digital Camera Questions & Answers
manual
SDHC 16 GB memory card compatible with Pentax Optio 450
No, you cannot use SDHC cards with the 450. You can only use MMC and SD cards, 2GB and smaller.
8/1/2012 10:10:10 PM • Pentax Optio 450... • Answered on Aug 01, 2012
What kind of an USB cable does the Optio 450 use?
You should get the original Pentax cable- the Pentax I-USB7 USB Cable for the Optio WPi, WP & S55 Digital Cameras. It's compatible with the 450 as well.
2/15/2006 4:43:49 PM • Pentax Optio 450... • Answered on Feb 15, 2006
2answers
Optio 450 Lens Stuck Problem
the lens cover gets stuck sometimes. It just needs a gentle touch and it opens up. Only happened once to me. In my case it happened after my daughter held onto the camera with her finger on the lens cover.
9/8/2005 12:13:08 PM • Pentax Optio 450... • Answered on Sep 08, 2005
3answers
Power problem with 450
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
9/8/2005 12:06:57 PM • Pentax Optio 450... • Answered on Sep 08, 2005
2answers
Broken connector cable for Pentax Optio 450
Yes. The cables are sold too. I got a deal by buying a dock from compgeeks.com and it was cheaper than just the cable. So, go shopping.
8/30/2005 12:46:43 PM • Pentax Optio 450... • Answered on Aug 30, 2005
Took out memory card to transfer photos. returned card to camera and it indicated memory card error shut down leaving lens out.
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery. Never remove or insert a memory card while the camera is turned on!!!!!!
4/13/2018 10:21:33 PM • Pentax Optio... • Answered on Apr 13, 2018
HOW DO FIX FOGGY LENS AFTER BEING UNDERWATER ?
Put it in the airing cupboard to dry out for 48 hours
5/11/2016 9:02:20 AM • Pentax Optio... • Answered on May 11, 2016
2answers
Will 5 year old cameras take a 16gb card
Hi. Your camera is too old to accept that big a card. The camera will let you know what size it will accept. Just keep putting larger sizes until it stops. Hope that helps.
5/29/2015 4:55:34 PM • Pentax Optio... • Answered on May 29, 2015
Pentax Optio E20 will not turn on.
The green light only means the memory card is getting power. That nothing else comes on indicates a serious problem that requires a trip to your local camera shop for help.
2/6/2015 4:53:44 AM • Pentax Optio... • Answered on Feb 06, 2015
What battery do I use in the Pentax Optico WGII
The Pentax Optio WG-2 takes an OEM manufactured battery or one designed for it. Google "Pentax Optio WG-2 replacement battery" or do a Amazon.com search for the same and you'll get thousands of options where to buy.
11/7/2014 3:19:10 PM • Pentax Optio... • Answered on Nov 07, 2014
Camera saying connection fail when trying to transfer photos to pc via usb cable
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
9/15/2014 2:08:21 PM • Pentax Optio... • Answered on Sep 15, 2014
How long to charge battery
Most of the time the charge light will change from red to green when the battery is full.
8/28/2014 6:38:39 PM • Pentax Optio... • Answered on Aug 28, 2014
Pentax Optio 450 Digital Camera Logo
9 questions posted
Top Pentax Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Pentax Camera Expert? Answer questions, earn points and help others
View Most Popular
Optio Pentax
  • Optio Pentax
Most Popular Question
sdhc 16 gb memory card compatible pentax
  • Cameras
