20 Most Recent
LG KP170 Cell Phone Questions & Answers
How can i unlock free LGKP170;35704202017050300 I NEED TO UNLOCK FROM ORANGE NET WORK
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
I want to unlock my phone to use any network
you cannot unlock that yourself. you need to go to a service center and tell them you want that phone to have an "OPEN LINE" that way you can insert any sim of any network in your country or area.
Require back plate for a lg kp170
This phone only costs 20 pounds on a Uk PAYG tariff. I would either search ebay for a second hand one or just buy a new one and swap out the sim card.
I purchased cel phone lg
Yes, you can transfer the pictures from your cellphone to the computer.
To do this you will have to install the software on your computer from the disk which is supplied along with the cellphone. Then connect the phone to the computer via the USB port on your computer and start transferring the pictures.
Hope this solves your problem. Thanks for using FixYa.
Lg center speaker
send to iphone sevice centre to do it i think it because your phone the sound sistem is not good so go and change it .
How to reset to factory settings
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
