20 Most Recent
Pentax ZX-7 35mm SLR Camera Questions & Answers
I recently took a shot
Try dismounting the lens and cleaning the camera and lens contacts with a soft lint-free cloth.
Pentax zx7 sutter release unresponsive
Seems that the camera needs an overhauling, it is possible that the shutter mechanism gets jammed at times and does not release by its own.Only if you are able to remove and check the mechanism carefully must you try and open the camera - if equipped- or otherwise this must be left to an expert so as not to tamper the unit.
My camera has been put
Before using it I suggest you to keep it in a dehumidifier. Or a large airtight container with dehumidified silica gel. Keep it there for two or three days.
When a camera is lying around, fungus tends to grow inside. Also the metal parts become rusty. Dehumidifying and exposing to mild sunlight might reduce these effects.
Gentle patting might also relieve the problem. Don't pat too hard, or you will have more problems!
Let us know whether this solved your problem.
I recently shot three rolls of color film with my
The shutter assembly has failed, a common fault with all older autofocus SLR's. it's nothing to do with the autofocus itself, just that AF SLR's usually tend to have fully electronically operated shutters which cannot be serviced and repaired like older models.
The only fix is to replace it, but it's no longer available and even if you do find one the repair is not economically worthwhile.
If you're not too choosy as to the brand, then free similar SLR models complete with lenses are regularly available on FreeCycle and Freegle. It's where I got all of mine.
Black viewfinder
Slr mirror is stuck. remove the lens and try to slightly move the mirror up and down ( but not forcing it to move!)and pushing the shutter switch. Try also applying lighter fluid in the mechanism while operating or shooting, fluid will help loosen the stucked mechanism.
Cannot remove lens
Dear Shutterbug2,
To release the lens you need to push the lens release button which is on the bottom left of the lens mount, and then turn the lens counterclockwise. If this doesn't work then it is most likely a broken lens release button, and you should then bring the camera to an authorized service technician.
Sincerely,
Allan
Go Ahead. Use Us.
