20 Most Recent
Nokia E73 Mode Cell Phone Questions & Answers
Video 532359 eseries
Go to Settings/Tools then Profiles > Switch it to General or Press Power off Button Once then switch to General.
My Nokia E73 won't charge
First Option:mostly nokia chargers doesn't make problems...just try the following..connect ur mobile with a system (usb cable)...found out whether it is charging or not...if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...if it charged with usb cable buy a new chargerPlease change Phone Bettery and check the chargingIF Charging Problem not Solved SoSecond Option:Your Phone charging IC Fault So Please change charging ICAnd charging Problem will Solved Quickly
Offline mode on nokia e73
Most of this problem comes due to failure of Connection between the Sim card and the Sim card slot.Since, there is no separate Sim card IC the only thing you need to check is to clean the Sim card connector or sometimes the connector might bend.Moreover, you can at least insert other Sim card and try.Otherwise, contact nearest mobile repairing shop.Good luck.Thanks for visiting fixya
Nokia E73 PUK code
My dear:Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly SolvedBut:Don't try to enter a PUK code without knowing the right one.You need to call your service provider to get this code. It can be as many as 8 digits, and it is random. If you enter too many wrong codes, you can permanently damage the device. So Please You Go to Service officeand Get the Duplicate Sim From Office Oprater Same Your No Problem will Solved
How to unlock e73
hi are you in need to unlock your nokia e73 mobile from network then visit
theunlockarena.com here they ask you the imei number of your mobile .finally they send you codes to unlock your mobile.
I need a free unlock codes for my nokia e73 it is
Restriction code is nothing but the unlocking code for your mobile. Unlocking your phone just removes the SIM card restriction so that you can use other network's SIM card. To get the restriction code for your Nokia model mobile, just visit this site
Classicunlocking.com,In
this site just give your IMEI number , country & network lock after
that within a short period you can get the restriction code for your
nokia mobile............I hope this is helpful for you.......
