20 Most Recent Nokia C5 Cell Phone Questions & Answers
You can just share contacts on Nokia to iPhone with email. Just follow below steps.
You can take advantage of Gmail (or other emails provide contacts sync function) to sync Nokia contacts to iPhone. The following tutorial will show you how to do it:
  1. Log in Gmail on your Nokia phone, and check the "Sync Contacts" option (If you are first time to use this method.
  2. After Gmail Contacts synced with your Nokia Contacts, you should turn to iPhone, and tap Settings > Mails, Contacts, Calendars, and tap Add Account. Then choose Google, and enter your Gmail account.
  3. After adding Google Account, you can turn on Contacts, and iPhone will ask whether you want to merge with your iPhone contacts. Click Yes and the contacts will be synced to your iPhone.
With the sync function of Gmail, people are able to transfer contacts from Nokia to iPhone with ease. If you aren't using Gmail on your iPhone, don't worry, you can take advantage of other email services like Yahoo, Outlook and so on.
For more methods, check: How to Transfer Contacts from Android to iPhone
Nokia C5 Cell... | Answered on Aug 29, 2019
i forget my nokia c5 phone lock code pls help me
Nokia C5 Cell... | Answered on Jun 19, 2019
formate your phone
Nokia C5 Cell... | Answered on Feb 17, 2019
pl. install nokia PC suite which comes in a CD supplied alongwith the phone. You can easily transfer files including music, pictures and video.
Nokia C5 Cell... | Answered on Nov 21, 2018
i'm having nokia X6 Handset, unfortunately i forget the mail as well as the password of the account of OVI.
Please assist how can i open fresh account with Nokia OVI Stores and music as well
Nokia C5 Cell... | Answered on Nov 02, 2018
if you hold finger on the volume up button dial a box comes up on the bottom of the screen says do you want to stay offline you press no and the phone will reboots itself into normal mode
Nokia C5 Cell... | Answered on Mar 17, 2018
- To unlock you Nokia C5 (if forgot or lost lock code) you can unlock it using a master code. - To get the master code i need the IMEI code of your mobile phone. - With the help of
this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by
typing *#06# into the phone keypad.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nokia C5 Cell... | Answered on Dec 17, 2017
Even though it is not activated, one or few of your current applications dialing a data call over your network. If that is not the case, may be your service provider keeps reducing your account due to a problem of theirs.
Other than that, it may be an unwanted software which makes the call(I do not like to call this a virus)
I'd suggest you contact your service provider and talk with this.
Nokia C5 Cell... | Answered on Jun 20, 2017
This is your master code 0334250076 , if anything goes wrong please let me know. Thanks
Nokia C5 Cell... | Answered on Jun 03, 2017
do you dosnload the version meant for your phone specifically and on whiuch website do you download your apps from try using umnet and seleect your phone,hope this helps
Nokia C5 Cell... | Answered on Apr 30, 2017
Good day. If you have a card reader, follow the simple procedures. Pull off the memory card from your phone and use the card reader and insert it on your pc. Now download the file to your pc and save it on your memory card. Then insert back the memory card to your phone from there open the file that you save and run it on your phone.If you have a cable provided by your phone unit, you can even use it as an alternative way, same procedure. Thanks
Nokia C5 Cell... | Answered on Jan 10, 2017
call customer care and ask them for block that number. they will block that number. don't forget to rate my solution.
Nokia C5 Cell... | Answered on Nov 11, 2016
Nokia C5 Cell Phone Logo
860 questions posted
Popular Products
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
Zaid Anarwala
Zaid Anarwala
View Most Popular
Nokia Cell Phones
  • Nokia Cell Phones
Most Popular Question
nokia c5 in offline mode
  • Cell Phones
