20 Most Recent
Worldtech Devices GYRO Sky Trooper 35CH Land And Sky Electric RTF RC Helicopter Questions & Answers
Saturn-x 2ch ir helicopter won't turn on
In my case (after a few crashes on Christmas morning) the bottom rotor stopped working, causing the copter to spin around on the ground uncontrolably. I traced the problem to a broken wire which is supposed to connect the motor to the PC board. There are four power wires, two for each motor. The front motor which powers the lower rotor has two wires, black and white. The upper motor is powered by the rear motor which has red and blue power leads. They are all supposed to be connected to four solder connector points laid out in a square pattern at the front, starboard corner of the PC board. In my case the black wire broke at the solder point on the PC board. I don't have a solder gun fine enough or hands steady enough to re-solder the connection so I will be looking for some electronics guy to fix this for me. It should only take a few minutes for someone who does this regularly and we will be airborne again!Hope this helps.Jerry
9/20/2015 6:22:43 PM •
Worldtech...
Answered
on Sep 20, 2015
I bought a World Tech
Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
Turn on the helicopter and you should be OK
11/30/2013 4:19:58 PM •
Worldtech...
Answered
on Nov 30, 2013
Helecopter charging port devective, never would
FixYa is an independent site that is NOT associated with any manufacturer or service provider. It is geared to advise / help people via messaging here; to repair items that are no longer covered under a manufacturer's warranty. FixYa does not sell / provide parts nor does it provide repair persons to perform labor. You should always either return the item to where bought or contact the manufacturer to obtain warranty service first, as many repairs will require opening (or similar work) that will often void a warranty or prevent a store from accepting a return.If you are out of warranty and do not wish to pay to have an item repaired, post the manufacturer's name & model - along with a full description of the problem you're having. The more complete your request is - the more likely ( and sooner) you'll get a reply from someone that may be able to help you get it working again for much less than buying new or sending out for repair. Good luck!
9/9/2013 7:42:31 PM •
Worldtech...
Answered
on Sep 09, 2013
