20 Most Recent
Team International Hawk Talon V3 RC Indoor Helicopter Questions & Answers
The helicopter will not synchronize
Press the throttle up and and back down and hold down a few times, sometimes it help to move left right knobs also. Try on each channel to get it synced
9/15/2018 3:49:00 PM •
Team...
Answered
on Sep 15, 2018
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
3/14/2015 1:33:33 AM •
Team...
Answered
on Mar 14, 2015
My rc fastlane hawk4 wont fly foward
hi..i want to suggest to you is to kindly open the remote control and and see all the buttons... the f the button for forward is in sticky key.... replace it and buy a new button key... or go to the nearest electronics shop to you... i hope it will help... thank u and god bless
3/13/2012 4:16:31 AM •
Team...
Answered
on Mar 13, 2012
I dont know what band my helicopter is on
I'd use band A and it always works, except that it makes my ihome turn on, switch modes and radio stations, so I use band c. To connect to the heli, turn the helicopter on, wait for a red light to blink inside, then throttle up and down on your remote. Then, your all set. Just do some preflight checks and have fun!
12/15/2011 6:57:21 AM •
Team...
Answered
on Dec 15, 2011
My talon v3 lifts but
Hello.
My son has a similar helicopter. When first purchased, it would not stay up as well. We returned the helicopter and the vendor realized that the cable was faulty and provided us with a USB charger to use to charge the batteries. He said not to charge it via USB for more than 5 minutes.
If just purchased, I'd advise you to do the same, if possible.
Hope this helps.
3/8/2011 9:24:48 PM •
Team...
Answered
on Mar 08, 2011
My hawk talon v3 will not lift off the ground and
The lower rotor has a problem where the gear on the motor shaft slides down and does not engage with the rotor gear. You can reach in through the skeleton with a small screwdriver and push the gear back up to engage. Happens every now and again, usually after a crash.
1/9/2011 1:56:28 AM •
Team...
Answered
on Jan 09, 2011
My hawk talon v3 is doing everything fine except
try taking the body off of the skeleton and cleaning the rotor cylinder, might be dirty or have some carpet/hair fibers keeping the blades from running at full speed even if the battery is fully charged
1/8/2011 2:14:50 AM •
Team...
Answered
on Jan 08, 2011
Hawk talon v3 wont get
I too had the lift-off prolem and I fixed it by gently pushed the upper gear all the way up, using a nail through the bottom of the copter and a hole in the lower gear, while pushing the lower rotor down.
12/30/2010 10:08:11 PM •
Team...
Answered
on Dec 30, 2010
