20 Most Recent
Yahoo YDP305 DVD Player Questions & Answers
Our
that DVD player the laser that read disk is getting damaged it got colour red which means it getting old and it plays tomuch
MULTI REGION
1. Switch on the DVD - without and DVD in it.
2. When "no disc" appears press the following sequence of numbers from the remote control: 9735
3. Choose the region (0 is universal)
I cannot play dvds / always says Wrong disc
I think I had the same problem, I went into setup and it was set to SCART, but I'm using the red, white and yellow leads, so I changed to the option at the top of the menu and it now works fine.
Still can't find the unlock codes though !!!!
Unlocking Mikomi DS-306 Dvd player
Partial solution...
Without a DVD in the player - eject the tray
1). Press Setup ensure you are showing 'General' tab
2). Enter 1389
At
this point a list comes up with all sorts of info. At the bottom is
Region Code 2. But I'm stumped as to how to change it. I've tried all
different key combinations I can think of. On other Mikomi players except the ds-306a (the Argos is a rebadged Mikomi ds-306a) you can then use the up or down arrows and cycle throw the region nunbers until you get to region 0. Odd that it doesn't seem to work on ds-306a. Perhaps someone else can figure the final steps out
Troubelshooting of YDP 530 DVD player
Diamond Electronics makes/made Yahoo DVD players
http://diamond-electronics.com/NewOne/index.html
Manual & some Trouble shooting
http://diamond-electronics.com/NewOne/productInfo/ydp530.html
No lee discos
Cuando se oye el disco dar vueltas por unos segundos, y despues el
lector acaba sin leer el disco con un mensaje 'no disk' , y esto pasa
con todos los discos, entonces sinifica que la lentilla laser esta
estropeada o bien suzia.
Intente limpiar la lente utilizando un disco limpiador como esto :
CD,DVD Cleaner Kit High Quality
Si esso no sirve necessita limpiar la lente directamente con algodon y alcohol, o sostituirla.
How does my mum reinstall this dvd on a new tv
Advd player does not need tuning , simpley connect red white and yellow RCA leads from the back of your DVD to AV... input of tour TV use TV remote to select the same AV source eg AV1 AV2
Playing DIVX on an LG LH-RH3690 DVD recorder
You can not view from the USB, since the USB port on the DVD player is ver 1.1. The transfer speed is to slow to watch a movie. Alternatively you can copy your movie from your flashdrive to the harddrive and watch from there. You will see what I mean with slow speed when you copy the movie. It takes ages.
I need a manual for
I need a Manual for a Sharp Dv-nc70 - combination VCR/DVD player. I have just moved countries and can't find it anywhere, I can't get sound on my tv when I hook up the VCR part
Thanks!
