20 Most Recent
Hyundai ImageQuest HQL320WR 32 in. HD-Ready LCD Television Questions & Answers
There is a black line all the way across the
It sounds that the connecting wire, between T'Con board and LCD panel has a loose contact in any one end of its connection socket. Re-seat this flat cable [LVDS] once, and check. If you wish to get more details, check this link. Screen-shots to defective panel to LCD TVs are given. You can compare them to that of your TVs' and make sure about the fault.
Pull up previous posts by its left sidebar, or type in the
brand name and model number to of your set, to its search box, and
press '
Enter' or view it in
Mosaic / Timeslide
option.
10/2/2013 2:28:52 PM •
Hyundai...
Answered
on Oct 02, 2013
I have a Hyundai E320
Make sure all the cords are plugged in and not frayed but,
Something about LCD's is that the lightbulb may be going out...this can be very expensive but uo might be able to get it from the manufacturer's website
Best Regards Lauren940
7/13/2011 8:15:36 PM •
Hyundai...
Answered
on Jul 13, 2011
I downgraded my cable to
Is this in fact a Hyundai ImageQuest TV? You should be able to go into the menu of the TV and in there will be a CHANNEL SCAN function. Look around for it... go into that and it should start scanning through the channels are configuring them.
However you should be able to just go to channel "22" for example by just typing it in... If it doesnt then something larger may be going on with the cable itself, not the TV. Try a channel scan first. If you can't find it, please write back with the model number of the TV
Thanks
Tim
9/20/2010 9:32:56 PM •
Hyundai...
Answered
on Sep 20, 2010
Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
3/1/2010 8:41:05 PM •
Hyundai...
Answered
on Mar 01, 2010
I have a Hyundai 32
What do you mean "main power fuse"? Are you referring to the house breaker, or the fuse inside the TV?
11/12/2009 10:53:02 PM •
Hyundai...
Answered
on Nov 12, 2009
I have the same problem. Audio no sound.
You will have to take the back off and take the number off of the inverter board which will be the board on the left or right side of the set. Use google would be your best chance.
7/9/2009 3:46:35 AM •
Hyundai...
Answered
on Jul 09, 2009
