20 Most Recent
Minolta 10x25 Activa D WP XL Pocket Binoculars with Free UPS Shipping Questions & Answers
One image is slightly above the other at all
The oculars are not aligned properly causing double vision. Check on the binoculars to see if there is a place to adjust the alignment of either of the oculars. Look for any loose screws that may cause the two oculars to be out of alignment.
If this is not the case try adding some torque to the binoculars to see if the will adjust to where they will both point in the same direction. The eyes can fuse disparate images slightly but there is a very small range that they can handle. If the two images are separated by more than this small amount it will cause eye strain and double vision.
Eye piece lens detached
Find best compact bird watching binoculars for sale, best compact spotting scope that let you get closer to nature. Welcome to www.falconstare.com.
Tighten minolta 10X40 j-B35
Cloudynights person says it was very difficult to get the cap off the hinge so that he could tighten it. He had to hone small screwdrivers until he could pop off that hinge (it is so well sealed for the WR rating, I suppose). Then he could get to the bolt that tightened the hinge so the binos stopped flopping about. I still don't know how he got that cap off, though.
