20 Most Recent
Sony Bravia XBR-52HX909 52 in. LCD HDTV Questions & Answers
I've notice while watching Baseball
This problem u must play with the tv orignal remote.Look on the tv original remote for a buttons like Aspect Ratio,Picture Sizes,VIEW MODES,ZOOM.Just pushes one of these buttons until u have the desire screen format for u.The screen will jump every sizes,u can't get evrythings u want,have to give and take as the tv pictures exspan or contract.
I have a sony 3d tv model xbr-52hx909 how do you
The resolution is controlled by the video sources, you do not adjust it at the TV, if you feed it with video sources that is 1080i it will display 1080i.
I hope that will explain how it works.
I was watching a dvd on my week-old Sony Bravia
This tv only a week olds,should never having this problems already.The tv should be return and get a new tv for the replacement,this tv have tv Tuner signal board or tv power supply board distrubution problems.Even when the store test it out it work,don't take that tv back.Insit they give a new tv for the replacement.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site.
thus the net in flix.
what did you mean by hooked?\
do you have internet at home at all?
do other things in home work to the internet, like PC or cell phones.
what I can not under stand is (different room) this phase
implies some rooms do work (netflex)
and wifi gets weak if my move any TV farther from the home router
and will fail past 25 feet or more. wifi is super weak through walls
for sure brick, or 2 walls.
if home is small one wifi access point is all you need
if huge home more.
distance matter, TV to router.
no TV model # told. (tells me wifi spec)
if you said my TV works in room 1 but not room 2, wifi;.
it be super more easy to answer.. is this true?
if true , get a tech to upgrade your wifi.
or go wired, Ethernet.(a better home upgrade)
No sound some channels
HI
IN THIS CASE YOU LED TV CHANG AUDIO FORMATE PLEASE GO TO TUNING SECTION THEN IN FINE TUNING AND THERE IS SOUND OPTIOND LIKE BG DK I AND M SELECT ONE ACCORDING TO YOUR COUNTRY
THANKS
M NASIR
