20 Most Recent
Fisher Price Deluxe Jumperoo Questions & Answers
Jumperoo does not spin
WD40 is a bad choice as a lubricant. The "WD" stands for "Water Displacement" - while it is an oil and will lubricate, it's mainly designed to drive out water from a wet ignition, rusty joints etc. It also has a tendency to attract and hold dirt/dust.Silicone spray lubricants are the best option. I often find when I buy something for the kids, the moving parts don't move as freely as they should. Spraying silicon lubricant right into the joints (hinge, axel, etc) and working the joint vigorously usually works.
I got a jumparoo delux but its from 2003 and i
They just pull up they will hold an average 3 small wettings, or one large wettings, they do no not allow the child to feel wet though so put the child in a pair of big boy undies under the pull ups, if being used for potty training. As usual change as soon as soiled.
These pull ups have next to nothing in the way of oder control, and are rubish for night time use if your child sleeps on their side.
I need instructions for fisherprice
Download from http://www.fisher-price.com/inst_sheets/K6070e-0720.pdf
If this not your jumperoo, visit the page
http://www.fisher-price.com/fp.aspx?st=2002&e=search&type=keyword&pcat=b_babygear&x=0&y=0&keyword=Jumperoo
select your product and in the bottom of page you will find link to instruction manual in PDF format to download.
I just purchased the Fisher
There should be a fabric strip that goes through 4 places on the jumperoo, under the seat part, and that fastens underneath by fitting over a small metal lever. Put the seat upside down, pull the front straps through the bottom a little to get some slack, pull the metal levers on each side forward (there is a small catch they are placed in when the jumperoo is in use; you'll have to move them up and forward to get them out of place and maneuver them so you can reposition the straps) and pull the straps off the metal levers. You can then choose the next tightest setting for the straps and push the metal levers back into place.
Hi i need the instructions
hi here is one
http://service.mattel.com/instruction_sheets/K6070a-0720.pdf
if not correct try here for the right one
http://service.mattel.com/us/results.aspx?SubContentType=IS&ContentType=Product&Ntt=jumperoo&x=0&y=0
Install baby capsule
What is a baby capsule? Car Seat?Each car is different to each car seat. I know my insurance company helps out if you ask as does the local police department. Best place to start is with your cars manufacturer.
I wanna install a printer
Check the manufacturers website,,for driver info or what if any printer s and devices u can install to the device,,check manual also good luck,,www.fisher price.com..support and register ur products ,,good luck
Fisher price aquarium cradle swing won't swing
It's been a while since I have dealt with these. There is usually an off switch located along the swing bar check to make sure it is in the on position and that the switch itself hasn't been disconnected. Double check to be sure the swing is level and the safety isn't stopping it from working.
Fisher Price Baby monitor model
Hi there, you can download the manuals for that certain model here:
http://service.mattel.com/us/%2Finstruction_sheets%2F71580pr-0920.pdf
http://service.mattel.com/us/%2Finstruction_sheets%2F71580a-0920.pdf
How do I obtain a
SIMPLY GOOGLE FISHER PRICE AND THEN PUT IN BABY MONITOR AND YOU SHOULD BE ABLE TO GET THE INFO ON LINE.
2ND OPTION WOULD BE GO TO ASK.COM AND TYPE IN MANUAL FOR FISHER PRICE BABY MONITOR AND THE MODEL NUMBER WOULD PROBABLY BE HELPFUL
