20 Most Recent
NEC VT465 Multimedia Projector Questions & Answers
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
4/9/2014 4:04:03 AM •
NEC VT465...
Answered
on Apr 09, 2014
Infocus projector is showing upsidedown
Sounds like you have to scroll thru the video settings upside down is the setting for projectors mounted on the ceiling simple fix though you may have to stand on your head to read the setting options :0)
8/23/2013 12:46:26 AM •
NEC VT465...
Answered
on Aug 23, 2013
Nec projector not coming on
Yep, there is a switch that enguages the lapm cover is opened, put the lamp cover back in place and the status blinking red light will stop, and projector will be ready.
1/9/2013 4:25:11 AM •
NEC VT465...
Answered
on Jan 09, 2013
I replaced the projector lamp
hi,
Did you reset the lamp hour after replacing the lamp. If not do the following for the same and try again. Also check is the lamp inserted is correct or not. Also check the lamp cover is properly closed or not.
press the "Help" button on the remote control for a minimum of 10 seconds while in standby mode. When the lamp time clock is reset to zero, the LAMP indicator (red light )goes out.
ok
2/10/2011 5:43:08 AM •
NEC VT465...
Answered
on Feb 10, 2011
I HAVE 2 NEC VT465
hi,
go to picture adjustment menu and select tint adjustment according to ur preference.
ok
12/17/2010 5:18:39 AM •
NEC VT465...
Answered
on Dec 17, 2010
I mounted my In Focus Projector upside down
Go to the Setup menu and select Orientation. In here, you will want Ceiling Front or Ceiling Rear depending on how you are using the projector.
Some projectors won't let you into the menus unless there is a computer connected. I'm not sure if this is one, but keep it in mind if you have trouble.
9/28/2009 2:19:16 AM •
NEC VT465...
Answered
on Sep 28, 2009
