download the software from Specotech.com called "IPINSTALLER"!
It will find the dvr on the network and display it's network properties in the white area of the screen. At this time you can change the network information to something compatible with your network then click syncronize
to use an systerm remote cameras you need a provider, web cams can be on a ip address but to secure them so only allocated uses use them there is a user name and password. this is setup when the ip address is setup. like this system, Configure Swann Wireless IP Network Camera with CameraFTP Service for... there are meany systems but they should tell you the one to use this may help you understand. my own setup works from any device as lone as you know the password not the ip address as the software all read knows the address. and is cloud base so can use the cloud to watch pre recorded items up to 30 days ago . hope this information help you.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock to many popular brand TVs are given.
Question edited for clarity and add CAPS.
To update the software, it has to be connected to the Internet, and it sounds like there is no internet connection via the television, so it is looking for a USB Cable to a computer.
https://www.google.com/search?q=ematic+at103b+update+the+software+version
JustAnswer
https://www.justanswer.com > Ford Repair
Jun 10, 2007 - I need the wiring diagram for the factory radio on a 2005 GMC/Yukon - Answered by a verified Ford Mechanic.
1 answer · Top answer: Hi, beloware the diagrams, I had to break them up being they were so big, thanks ...
Pinterest · dominiquesawadogo
3 years ago
55 Luxury 2004 Gmc Yukon Bose Radio Wiring Diagram- Car radio installation trimmings comprise of harness adapters leads, fascia adapters, ...
JustAnswer
https://www.justanswer.com > GMC Questions
Feb 17, 2015 - I need the wire diagram for 04 Yukon with the Bose system the pin lay out that plugs in the back of the radio. Share this conversation.
1 answer · Top answer: Gary : Welcome! My name is ***** ***** I will do my best to assist you with this problem. ...
