20 Most Recent
CSi Speco DVR-PC8 Video Recorder Questions & Answers
My speco reemote will not
Hello
Open the "internet options" menu through tools. Click on "security" tab. Then select the "internet" and click on custom level. Here, navigate to the "Activex controls and plug-ins" section. Change "Download Unsigned ActiveX Controls" to "prompt" and do the same for the setting directly below that. This should clear up your problem
8/6/2014 6:14:04 PM •
CSi Speco...
Answered
on Aug 06, 2014
Activex blocking usage of speco remote
4/20/2013 2:32:46 AM •
CSi Speco...
Answered
on Apr 20, 2013
My speco dvr says no disk, how did this happen.
Sounds like you have a bad harddrive which is what DVR's usually record their data to. You need to take it in to get it fixed or if you can do it yourself, find out what kind of drive it has, e.g. the size of it, the interface (IDE or SATA) and then purchase one close to the same size and replace it.
12/30/2011 5:55:40 AM •
CSi Speco...
Answered
on Dec 30, 2011
I start using fifox as my default browser but
Firefox does not support the necessary dual streaming that is necessary for speco remote to work. I use Firefox for all my web surfing, but I have to keep IE on the puter to remote access any Speco DVRs that I am servicing. If you really don't like IE, then you will need to use the CMS software that comes with the DVR system on a seperate disc or download it from Specotech.com.
12/6/2009 8:00:35 PM •
CSi Speco...
Answered
on Dec 06, 2009
My daycare says that they
to use an systerm remote cameras you need a provider, web cams can be on a ip address but to secure them so only allocated uses use them there is a user name and password. this is setup when the ip address is setup. like this system,
Configure Swann Wireless IP Network Camera with CameraFTP Service for... there are meany systems but they should tell you the one to use this may help you understand. my own setup works from any device as lone as you know the password not the ip address as the software all read knows the address. and is cloud base so can use the cloud to watch pre recorded items up to 30 days ago . hope this information help you.
7/1/2017 4:41:00 AM •
CSi Speco...
Answered
on Jul 01, 2017
