20 Most Recent
ASUS 16GB MeMO Pad 7" Tablet Cherry Pink Questions & Answers
What can I do, Asus tablet says "launcher has stopped" and will not do anything?
Always try a reboot first. If that fails go into settings, go to apps, then might have to go to system apps, see if you can start it from there. If it starts and stops, could be another app is interfering or you got too much installed and are low in memory. You can try to install a startup manager app and make sure to turn off all unnecessary apps from auto starting. If that fails, you can then try to reset to factory defaults and start all over. Just reinstall your apps one at a time and make sure system is stable after each install.
How do I access offline books downloaded to my Asus MEMO Pad 7 books from Scribd ?
This depends on what format they are in (epub, mobi, pdf, html, txt or a range of others) You may need a special reader for that format.
I use a library organizer calibre which contains a converter and a viewer which supposedly allows you to convert books between different formats and to read book in a variety of different formats. You must add the book to calibre to be able to read it. It's free. I have a kindle but that only reads mobi formats, and reading epub books atm so calibre works well for that. I have not used any of the "library" functions so far. I found it quite difficult to learn at first.
8.February.2015
