20 Most Recent Konica Minolta DiMAGE 7i Digital Camera Questions & Answers
Some sellers have some pretty good aftermarket replacements. Give them a look. Sony Center was makeing this job at 2010, but no more; even way, you could try calling at Digital Product Support: 1-877-462-4464 . Also, try asking in this link for Minolta Support site; additionally, I quote some comments about this part...
I got the round eyepiece from Orion Store Site and it fit perfectly. I liked it so much I adapted one to my more recent Panasonic. It was a perfect fit for the D7i. You stretch the rubber around the existing eyepiece.
Also, could try to contact with this seller: EC-1200-KONICA-MINOLTA-EYEPIECE-CUP-Dynax-5-4
Hope this helps.
Konica Minolta... | Answered on Jun 21, 2011
I suspect 2GB is the maximum the camera will take. A 2GB Sandisk card works in my 7i. When the DiMAGE 7i was launched, 256mB was about as big as CF cards got!
Konica Minolta... | Answered on Mar 30, 2011
Hello Sir
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Konica Minolta... | Answered on Aug 29, 2010
Sometimes if batteries are allowed to completely discharge, they cannot come back.
Konica Minolta... | Answered on Dec 02, 2009
You need to format the new card in the camera before using it.
Konica Minolta... | Answered on Sep 09, 2009
Having researched the internet - I've found a Minolta branded flashgun suitable for your camera. It has the bounce flash you ask for, however it's not cheap.
Here's the link:
http://www.crazycameras.co.uk/index.php?act=viewProd&productId=9097&aff_code=gg
Konica Minolta... | Answered on Jun 02, 2009
I just found a solution to my camera problem. It turned out to be the batteries. We purchases some Rechargable Duracel with a 2650mAh rating. After charging the batteries I put them in the camera and it started right up and was taking photos like when we first bought it. I have not been able to use the camera in almost 2 years and it turns out the problem was weak batteries.
So anyone that has a Minolta Dimage 7i and cant get it to turn on make sure you have at least 2650mAh rated rechargable batteries. The higher the mAh rating the better.
Hope this helps someone else. We are ecstatic that we can use our camera again. No more using my camera phone!!!
Konica Minolta... | Answered on May 17, 2009
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
DONT FORGET TO RATE;
Konica Minolta... | Answered on Oct 10, 2008
go to www.memorysuppliers.com order the below item
1 SDCFB-1024-A10 - SanDisk 1GB / 1024MB Compact Flash card
Konica Minolta... | Answered on Oct 04, 2008
Here are some simple things to try first for a camera that won't power on:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Konica Minolta... | Answered on May 03, 2008
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Konica Minolta... | Answered on Mar 12, 2008
The camera does not require a new CCD. This problem is most likely due to a stuck or malfunctioning shutter mechanism in the lens. Normally the camera will open the shutter to allow you to see the image so you can compose, and then when you take the picture it will close the shutter momentarily and record what the CCD saw at that moment. If the shutter does not open in the first place - all you see is black. If this is in fact your issue the camera will need to be repaired. David Millier Advance Camera Repair
Konica Minolta... | Answered on Jan 26, 2008
This is an update. Sony is now handling repairs for the defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so for others who have this problem get going! See this link:
Konica Minolta... | Answered on Dec 14, 2007
go to the Konica Minolta customer technical support[now part of Sony] However I doubt an item of this age is repairable due to lack of parts.
Konica Minolta... | Answered on Jul 17, 2007
Konica Minolta DiMAGE 7i Digital Camera Logo
42 questions posted
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
View Most Popular
DiMAGE Konica Minolta
  • DiMAGE Konica Minolta
Most Popular Question
minolta 7i camera totally dead batterys
  • Cameras
