20 Most Recent Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC Questions & Answers
you received error 13042 when either one of 2 things:
1. when downloading something hiccuped and caused a bad zip file
2. when installing something went wrong and could not be installed....
solution is to delete the old zip file and download fresh from adobe.com
The link was ftp://ftp.adobe.com/pub/adobe/reader/win
Microsoft... | Answered on Jun 15, 2015
http://www.brighthub.com/guides/usb-flash-drive.aspx
complete guide to usb drives
at least 4gb you might be better of getting something larger say 8gb depending on your budget
hope it helps
Microsoft... | Answered on Jun 01, 2014
You could run the chkdsk disk utility Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive or an easier way to run the chkdsk utility Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. Hope this helps.
Microsoft... | Answered on Dec 17, 2012
if you have another player installed it may be conflicting..deactivate.reboot...it and try it ..if that doesn't work delete the download and re install..always reboot
Microsoft... | Answered on Dec 10, 2012
1-unplug your network wire
2-donwload from an other PC a firewall and an antimalware
3-Move downloaded file to infected PC
4-install firewall and antimalware
5-scan your PC and reconect it
Microsoft... | Answered on Nov 15, 2012
If you havent restoration point you might reinstal windows and if its an illegal version never instal media player and i.e. update
If you have the instalation disk the best choise is to save your documents and reinstal windows else there are an option in the setting panel(on my winXP)
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Microsoft... | Answered on Oct 17, 2012
First, update your java runtime environment software to the latest version for here:
http://www.java.com/en/download/manual.jsp
Then update your Adobe flash player software to the latest version.
For Internet Explorer you need this update:
http://majorgeeks.com/Adobe_Flash_Player_for_Internet_Explorer_d5163.html
For Firefox, Netscape, Opera and Chrome use this update:
http://majorgeeks.com/Adobe_Flash_Player_for_Firefox_Mozilla_Netscape_Opera_d7806.html
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Microsoft... | Answered on Sep 04, 2012
1.From Start>Administrative Tools>Internet Information Services
2.Expand the left tree, right-click your WebSite->Properties
3.Click on Directory Security, then in "Anonymous access and authentication control" click on Edit.
T4.ick "Allow IIS to control password", then OK and come out of IIS.
If it is not work then you need to reinstall again.
If you need any kind of technical assistance you can contact support cell at vtechsquad.com
Microsoft... | Answered on Aug 29, 2012
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab (right click on the time to adjust)
hope this helps
Microsoft... | Answered on Aug 10, 2012
download xp validation patch file
Microsoft... | Answered on Jul 24, 2012
no, they must stay installed because they contain additional security features, the updates are cumulative.
Microsoft... | Answered on Jun 10, 2012
you need to put the xp on you want shut the computer down restart the computer press f6 and it will start to formatte just follow instrushions dear
kind regards peggy
Microsoft... | Answered on May 16, 2012
salam, probably dear check the drivers and update them. you can get online the drivers of what you said.hope you understand.
check me also
Microsoft... | Answered on Apr 22, 2012
Microsoft Windows XP Professional Full Version (E85-00086-RB) for PC Logo
62 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XP Microsoft
  • XP Microsoft
Most Popular Question
iis asking username password
  • Computers & Internet
