20 Most Recent Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Questions & Answers
DIAGNOSTICS DOWNLOAD HIREN BOOT CD, WRITE IT TO CD THEN BOOT FROM IT http://rapidshare.com/files/33987018/NYU_Hiren_s.BootCD.9.1.rar Includes HDD Diagnostics for these companies Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - SeaTools for Dos 1.08 - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 3.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics Hope this helps ====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Microsoft... | Answered on Oct 27, 2019
.swf files are Flash files and are played by the Adobe Flash Player. If you currently have the Adobe Flash Player installed, try going to Start --> Control Panel and clicking on Add/Remove Programs. When the screen loads click on Adobe Flash Player and click Uninstall. Finally restart your computer.
When the computer reboots, use the below link to install Adobe Flash Player.
http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Version=ShockwaveFlash&promoid=BUIGP
Thanks for your question!
Actually, there are a lot of games with some kind of strategy. For example, Apex Legends that is not a strategy game but you still have to think in that way to succeed. You can learn more here https://apexstat.net/wiki/legends.
did you install direct x in your computer? if not then download it and get it installed and then try reinstalling the program
Microsoft... | Answered on Oct 26, 2019
Hello and Welcome to FixYa!
Best OS for gaming purposes is Windows Xp because it is compatible with approx all games new and old. And memory allocation of Xp is good for games. But since Windows Xp is not outdated Windows 7 is a very good alternative. Windows 7 does not load your PC at all, that means your game has more resources to use. Windows Vista is not at all good for games.
If this was helpful, kindly do rate me.
Regards,
Waqar.
Microsoft... | Answered on Aug 22, 2019
1)Safe Mode
Reboot your computer and as soon as Windows logs off, start repeatively tapping the F8 Key on your keyboard.  • As soon as you see the Windows Advanced Startup options select Safe Mode within Safe Mode get yourself into these folders…  • C:\Windows\System32 (Rename wgatray.exe to wgatrayold.exe)  • C:\Windows\System32\dllcache (Rename wgatray.exe to wgatrayold.exe)  Note: Dllcache is a hidden folder, to view hidden folders do the following, go to Start, Control Panel, Folder Options,  Select the view Tab and under the Hidden Files option, select Show hidden files and folders
2) Safe Mode Registry
Click on Start, Run and within the open dialog box type regedit and click OK.  • Within the Registry Editor navigate your self to  HKEY_Local_Machine\Software\Microsoft\WindowsNT\CurrentVersi on\Winlogon\Notify\WGALOGON  • Right Click and Export the WGALOGON Folder (this should be saved onto your machine for backup purposes)  • After Exporting the folder, DELETE the WGALOGON folder  • After deleting close all applications and Restart your machine back to Normal Mode  After being prompt of a successful validation, Restart your Machine
Microsoft... | Answered on Jul 13, 2019
go to www.gamespot.com
Dont forget to rate me
Microsoft... | Answered on Jul 11, 2019
Install SP3 instead. Don't bother with SP2 since SP3 has newer versions of drivers anyway.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Microsoft... | Answered on Feb 28, 2019
Hey Hi Shalin,
I believe u r not using the key that either is tagged with a branded system or on the cover of the WINDOWS XP DISK. Here, by Volume License Key (VLK) is meant that the PRODUCT KEY FOR WINDOWS XP has been used number of times and after that MICROSOFT has blocked it and it will work with the Computer from which it was registered.. In order to stop piracy MICROSOFT has done that, when a pirated version of windows is used online MICROSOFT record few details like MAK, Hard Drive Serial Number and few important details regarding the pc and on finding the PRODUCT KEY fraud they install WINDOWS GENUINE ADVANTAGE PLUG-IN into the system... If u have paid for the LICENSED VERSION of windows xp then contact the support person from where u bought it otherwise there are ways to remove it as well for that u can follow these steps....
FOR WINDOWS XP
THERE ARE NUMBER OF METHODS BUT FOR YOU THESE 2 METHODS ARE GOOD
1) METHOD:-
TRY SYSTEM RESTORE.
2) METHOD:-
2.1) LAUNCH WINDOWS TASK MANAGER.
2.2) End wgatray.exe Process In Task Manager.
2.3) Restart System In Safe Mode.
2.4) Delete wgatray.exe from c:WindowsSystem32.
2.5)
Delete wgatray.exe from c:WindowsSystem32dllcache.
2.6) Launch RegEdit.
2.7) Browse the following key HKEY_LOCALMACHINESOFTWAREMICROSOFTWINDOWSNTCurrentVersionWinlogonNotify.
2.8) Delete The Folder "WgaLogon" and all of its component.
2.9 ) Reboot System.
3.0) BE HAPPY NOW.... AND NEVER EVER INSTALL WINDOWS GENUINEADVANTAGE NOTIFICATION IN WINDOWS UPDATE OTHERWISE YOU HAVE TO REPEATTHE DAMN PROCESS AGAIN.
IN ORDER TO THAT FOLLOW THIS
START
--> CONTROL PANEL--> AUTOMATIC UPDATES --> CHOOSE THE OPTION """"""""""""Notify me but don't automatically download or install them"""""""""""
When u use this option whenever your system detects any new WINDOWSUPDATE choose the updates which u want to install... DON'T INSTALLWINDOWS XP SERVICE PACK --3.
If this doesnt work then follow this
{THIS IS THE LINK http://www.wikihow.com/Remove-Windows-Genuine-Advantage-Notifications}
STEPS TO REMOVE WINDOWS GENUINE ADVANTAGE
  1. If you have only just installed Windows Genuine Advantagenotifications, simply using the system restore function will remove theprogram. Then refuse to accept the WGA update next time Windowsupdates... Otherwise, proceed as detailed below. (NOTE: If you try these steps while you are in "Safe Mode," step #8 is unnecessary).
  2. First Try the Following:
  3. - Open a CMD Line Window by Clicking on Start ==>Run ==> type CMD and Press OK.
  4. - Change Directory into the System32 Folder (Like Cd c:WindowsSystem32)
  5. - Open a notepad Window and type the following lines:
  6. taskkill -IM wgatray.exe
  7. del wgatray.exe
  8. del wgalogon.dll
  9. - Highlight and copy to the Clipboard the three lines above
  10. - now Paste the the contents of the Clipboard to the CMD Window
  11. This should kill the wgatray.exe Process from the Taskbar andimediately delete both files wgatray.exe and wgalogon.dll without theneed to to go through all steps bellow.
  12. If that does not work, then continue and follow the steps bellow
  13. Open System32 by either A or B of the following methods:
    • a) syst32runok.pngClick "Start", "Run", then type-in "System32". Click "Okay".
    • b) Find System32 manually by clicking "Start" > "My Computer"> "(X:)" (Replacing "X" with the drive letter of the host ofWindows) > "Windows" > "System32".
  14. In "System32", go to "Tools" > "Folder options" > click onthe tab, "View" > Uncheck "Hide extensions for known file types". Now you can begin...
  15. Check to make sure the window that comes up has a full screen ofvarious files. The files are in alphabetical order, which makes iteasier to locate the specific file.
  16. wgarenme.pngFind "WgaLogon.dll" and rename it "WgaLogon.dll.bak".
  17. Create an empty copy of WgaLogon.dll:
    • crtebnkwga.pngRight click on a blank space in System32 and select "New" > "Text Document".
    • Leave the text document empty and label it "WgaLogon.dll". Press Enter (on your keyboard).
    • wgawanignoyeas.pngYou may get a warning from the above step that says, "If you change a file name extension, the file may become unusable. Are you sure you want to change it?". Click "Yes" on this warning.
  18. Be ready to complete the next two steps very quickly! Find"WgaTray.exe" in "System32" and delete it. You will then have 5 secondsto find "WgaTray.exe" in the Task Manager (the next step). NOTE: If you remove the files mentioned above while you are in "Safe Mode," step #8 is unnecessary.
  19. tskenproctb.pngImmediately open Task Manager. You can do this by pressing the Ctrl,Shift, and Esc keys simultaneously, pressing the Ctrl, Alt, and Deletekeys simultaneously, or right clicking the Taskbar and selecting "TaskManager". Click on the process tab and click end process when"WgaTray.exe" is selected. Note: If you take longer, do not panic!All that will happen is that "WgaTray.exe" will keep reapearing in theprocesses list (i.e. you won't be able to delete it as required). Toremove the notifications after this, return to system32. You will findtwo files:"WgaLogon.dll.bak" (the one you renamed) and an ApplicationExtension (0KB) called "WgaLogon.dll". Delete the ApplicationExtension, rename "WgaLogon.dll.bak" to "WgaLogon.dll" and repeat thesteps from the fifth one onwards (at a greater speed!!).
  20. Restart your computer once you have finished. All the notification messages should be gone.
Microsoft... | Answered on Feb 13, 2019
Hi, you have to activate your windows once again, in order to run genuine windows. To do that either you have to purchase the windows key or activate it via a tool. Another quick option is to take windows customer support help from here: +1888-315-9712
Read here the full process -
Activate windows via key
Hello Sir,
The Spring Framework (or Spring for short) is an open source application framework for the Java platform. The first version was written by Rod Johnson, who first released it with the publication of his book Expert One-on-One J2EE Design and Development (Wrox Press, October 2002). A port is available for the .NET Framework.[1]
The framework was first released under the Apache 2.0 license in June 2003. The first milestone release, 1.0, was released in March 2004, with further milestone releases in September 2004 and March 2005.
Although the Spring Framework does not enforce any specific programming model, it has become popular in the Java community as an alternative, replacement, or even addition to the Enterprise JavaBean model. By design, the framework offers a lot of freedom to Java developers yet provides well documented and easy-to-use solutions for common practices in the industry.
While the core features of the Spring Framework are usable in any Java application, there are many extensions and improvements for building web-based applications on top of the Java Enterprise platform. Spring has gained a lot of popularity because of this, and is recognized by vendors as a strategically important framework.
The Spring Framework provides solutions to many technical challenges faced by Java developers and organizations wanting to create applications based on the Java platform. Because of the sheer vastness of the functionality offered, it can be hard to distinguish the major building blocks from which the framework is composed. The Spring Framework is not exclusively linked to the Java Enterprise platform, although its far-reaching integration in this area is an important reason for its popularity.
The Spring Framework is probably best known for offering features required to create complex business applications effectively outside of the programming models which have been dominant historically in the industry. Next to that, it is also credited for introducing previously unfamiliar functionalities into today's mainstream development practices, even beyond the Java platform.
This amounts to a framework which offers a consistent model and makes it applicable to most application types created on top of the Java platform today.
[Modules of the Spring Framework The Spring Framework can be considered as a collection of smaller frameworks. Most of these frameworks are designed to work independently of each other yet provide better functionalities when used together. These frameworks are divided along the building blocks of typical complex applications:
  • Inversion of Control container: configuration of application components and lifecycle management of Java objects.
  • Aspect-oriented programming framework: working with functionalities which cannot be implemented with Java's object-oriented programming capabilities without making sacrifices.
  • Data access framework: working with relational database management systems on the Java platform using JDBC and Object-relational mapping tools providing solutions to technical challenges which are reusable in a multitude of Java-based environments.
  • Transaction management framework: harmonization of various transaction management API's and configurative transaction management orchestration for Java objects.
  • Model-view-controller framework: HTTP and Servlet based framework providing many hooks for extension and customization.
  • Remote Access framework: configurative RPC-style export and import of Java objects over computer networks supporting RMI, CORBA and HTTP-based protocols including web services (SOAP).
  • Authentication and authorization framework: configurative orchestration of authentication and authorization processes supporting many popular and industry-standard standards, protocols, tools and practices via the Acegi sub-project.
  • Remote Management framework: configurative exposure and management of Java objects for local or remote configuration via JMX.
  • Messaging framework: configurative registration of message listener objects for transparent message consumption from message queues via JMS, improvement of message sending over standard JMS API's.
  • Testing framework: support classes for writing unit tests and integration tests.
Microsoft... | Answered on Dec 19, 2018
You will need to contact Microsoft or an authorized reseller directly in order to get a Windows XP cd key.
Try reinstalling Spybot and then removing it, I had this exact problem once with someone and it was because their uninstall wasnt working right so i reinstalled spybot and then tried removing it again and it worked.
You must buy the software, it is cheap on eBay.
Microsoft... | Answered on Dec 18, 2018
its direct 3d driver: you need to reinstall the last version of directx, or perhaps your videocard driver before
is direct installed in your system? if not then download an install the latest version of direct x.then try reinstalling the program.
u better install windows 7 or updated os in ur system bcoz microsoft had stopped the updates for xp os. so i can say u to install latest updated os to rectify ur problem
Microsoft... | Answered on Oct 14, 2017
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
3,997 questions posted
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XP Microsoft
  • XP Microsoft
Most Popular Question
give me detail list best stragety games
  • Computers & Internet
