20 Most Recent
Konica Minolta Konica Bizhub C353 Drum Cyan Imaging Unit Questions & Answers
I have a trouble code C-3727 showing on my
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On:
Konica Printer Support
THE PRINTING IS TOO DARK
You may be able to "manually" change your colour balances settings through the printer settings on your computer. If the machine is stand alone or connected to a network, try getting the machine to recalibrate itself. If none of these have any significant effect - it will need to be seen by a service tech.
On C35 bizhun get error when scan to email SCAN TX
your email settings got messed up... you need to go to pagescope (web interface) by typing the ip address in your webbrouser that is connected to the network and check the scan settings to see if mybe you missed something or if something has changed....
ERROR CO C-FC22
Sir/Mam,
There is something wrong with Multi-function board. MFPB. Mite want to check all of the connectors on the board pull each one off check the pins then reseat them each !!!!!!! about 20 also check the board to board connections. The board cost about 1000 dollars give or take. Also mite be able to have at technician come out and re-flash the firmware, which can only be download from a secure Konica Minolta web site not on line for free. Also ensure your machine has a real good surge protectors not a $19.99 Ace hardware store one (Nothing against ACE:)) Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Konica c353 double side print
ARE you sure you have checked the box on print properties on you computer that says either left binding or top binding have to let the copier know which way to do binding will go so you don't have to flip the paper over to read correctly or it will be upside down on the other side. Left binding like reading a book,top binding like a classroom lecture notebook. Btw, I’m available to help over the phone in case u need at
I have Konica Minolta bizhub C353 and the paper
First Are informing the copier of the proper paper weight
? The paper weight is on the outer wrapping of the paper such as 75 g/m2 or 90 g/m2 etc. did you tell the machine that? Did you select the same weight when you sent the print job over to the machine in your print properties/perferencies ? They have to match! Check the orientation of the paper also ensue they match landscape or portrait? they have to match in the computer also. Btw, I’m available to help over the phone in case u need at
Error codes c2020
hI ARE U SURE ABOUT THE ERROR CODE OZ NOTHING ON SERVICEMANUAL ABOUT IT.
ERROR CODE C2163
First check the alignment front and rear of the finisher, check the finisher exit guide rollers if the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. that lower gear one might be broken by the pin slot.Or in case You Still Having Konica Printer Problem Then Follow Us For On:
How to clean rollers
what rollers are you refering too?? you cant clean the image units. they need to be replaced
