20 Most Recent
Telex H-531 Headset Questions & Answers
Headset not working
the problem might be due to the internal wiring damage.do not coil the wire much.you might have to replace it if damaged.
can also be due to the volume control, where there might be a connection loss.will wait for your further comments.good luck.
Headset not working
Could be a wire is broken on it. Do you still have the manual? Call the help line listed in it.
I have a set of
Do whatever it takes to duplicate the wiring of good earpiece to the one that is not working and that should resolve the issue.
I am Kush Agarwal and
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
I have a telex airmen
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
