20 Most Recent Amazon Kindle DX 2nd Generation Questions & Answers
I have a kindle that will not remember a password so I can down load books. I have ordered several and can't receive them
Have you been to the setting wheel at the top an set the check box to keep all passwords? Try this an see if its checked
1/29/2015 5:50:58 PM • Amazon Kindle DX... • Answered on Jan 29, 2015
Screen went partially blank
Well the first problem is kendels ****....get an ipad. You get what you pay for. Secondly there might be somethibg underneath the screen. To fix this you would have to take it to a place that replaces screens and have them clean it.
5/3/2013 9:48:15 PM • Amazon Kindle DX... • Answered on May 03, 2013
Where can I get a free instruction manual for my
Via this link from Amazon, you will find the manual via pdf format. You will be able to save it to your desktop as well as print it from the pdf.
File: http://kindle.s3.amazonaws.com/Kindle%20DX%20User's%20Guide,%203rd%20Edition_English.pdf
2/9/2011 10:44:48 PM • Amazon Kindle DX... • Answered on Feb 09, 2011
After two months with my Kindle, it says that
DEAR FRIEND, THE BATTERY IS TOO LOW THAT IS WHY IT WILL NOT COME ON. SO YOU WILL HAVE TO USE A UNIVERSAL CHARGER TO BOOST IT.
2/9/2011 8:20:32 PM • Amazon Kindle DX... • Answered on Feb 09, 2011
5answers
Kindle fire screen is blank
Try doing a hard reset of your Kindle Fire as advised on the Kindle Fire Support web site for dealing with Screen problemsIf you still have a problem after doing the above, then you follow the additional steps advised on the above web page, i.e. ensure the Kindle Fire is fully charged (the power indicator has changed from Orange to Green) and that you have the latest Software Updates installed (assuming you can view the screen to do so!).
6/12/2018 7:32:17 PM • Amazon Kindle... • Answered on Jun 12, 2018
2answers
Instructions for the kindle
See the Kindle Support web page and then select your particular Kindle device after which you can follow the instructions for that device which are shown on the web page.See the Kindle Documentation web page for further manuals
3/17/2018 4:34:01 PM • Amazon Kindle... • Answered on Mar 17, 2018
How long should a Kinlde d00901 battery last as in years?
just get a new one
6/8/2017 10:05:21 PM • Amazon Kindle... • Answered on Jun 08, 2017
Kindle fire screen is green
I was having this exact same problem. I did a little research but to no avail, until I found this site. Just as I went to test some of these suggestions out, I found the screen had just returned back to normal as if nothing was wrong. Maybe give it a little time to work? I've been using it during its screen problems and it seems perfectly fine (aside from the green tint). Now my kindle is as good as new, so maybe you just have to wait a bit.
11/6/2015 2:16:41 AM • Amazon Kindle... • Answered on Nov 06, 2015
2answers
My Kindle Fire will not start
If you last charged it with the computer USB port, try charging with the supplied AC adapter instead. If you last charged with the computer USB port, try charging with the AC adapter this time. This will help isolate a bad AC adapter / power cord or USB cable / USB port.It is important to note that if you are charging your Kindle via USB port on a computer, when many computer enters "sleep mode" the USB power is shut off at this time too. Charging is effectively halted - even though still connected. You should only expect to charge while the computer is active or when using the AC adapter. You can also purchase an aftermarket DC charger. These are small plugs that are inserted into your auto's port or cigar lighter. They provide 1 or 2 USB connectors to plug in a USB cable. These devices are suitable to supply / charge just about any devices that uses a computer's USB port to power / charge a device. They cost anywhere from $5 and up and look something like this:5_22_2012_12_50_36_pm.jpgI hope this helps and good luck!
7/17/2013 6:48:46 PM • Amazon Kindle... • Answered on Jul 17, 2013
Need maqnual for kindle
Here you go! Download the manual you need from there.
8/31/2012 5:09:24 PM • Amazon Kindle... • Answered on Aug 31, 2012
Unfreeze my Kindle Fire
Take the Battery out and the sim card leave for a couple of seconds and put them Back in and turn your phone on, it should work
7/2/2012 11:22:57 PM • Amazon Kindle... • Answered on Jul 02, 2012
Where can I get instructions on how to use my kindle
You should be able to find what you are looking for at the kindle support page on amazon.com
2/27/2012 9:51:19 PM • Amazon Kindle... • Answered on Feb 27, 2012
Kindle
You can find the instructions on Amazon's website, www.amazon.com .
1/9/2012 11:30:40 PM • Amazon Kindle... • Answered on Jan 09, 2012
2answers
Kindle set up
See the Kindle Support web page and then select your particular Kindle device after which you can follow the instructions for that device which are shown on the web page. See the Kindle Documentation web page for further manuals
1/9/2012 11:01:31 PM • Amazon Kindle... • Answered on Jan 09, 2012
Delete unwanted items on a kindle
On my Kindle you go to the Home screen, press the left arrow on the 5 way controller, and select Remove from Device.More information here, by selecting your Kindle model and then selecting from the choices which follow - Organizing Content - Removing Contenthttp://www.amazon.com/gp/help/customer/display.html/ref=kinw_myk_lnav_help?ie=UTF8&nodeId=200127470
1/5/2012 10:07:00 AM • Amazon Kindle... • Answered on Jan 05, 2012
My WiFi keeps going off even when I turn it on
I assume that you mean the WiFi connection on your Kindle keeps going off and that you have checked that other devices connecting to the same WiFi router / access point are not experiencing the same problem, only the Kindle?If it is only your Kindle having this problem, then it may be worth checking that you have the latest version of software on the Kindle which you can do by visiting the Kindle Support web link in this update - select your correct Kindle device then follow the steps to check that you have the most up to date software installed.The Kindle Keyboard should update itself automatically but can also be done manually if necessary.If that doesn't work, then you may need to Reset the Kindle by pressing the Power button for 20 seconds - this will do a re-boot of the Kindle OS which may cure the problem is it is caused by some temporary problem.Have you checked what your battery status is when the WiFi goes off - this may happen when the battery levels get very low - the WiFi will add extra drain on the battery and cause the battery life to be reduced if left on full time.
1/3/2012 4:55:03 PM • Amazon Kindle... • Answered on Jan 03, 2012
2answers
How to Download Alexa app for Echo device?
Also you can check out ifttt site for thousands of work around. Goof Luck. https://www.the-ambient.com/guides/amazon-alexa-missing-manual-130 Set Up Your Echo
4/17/2024 10:33:07 AM • Amazon Computers... • Answered on Apr 17, 2024
Grace Mondo Elite Digital Radio. The presets not working doesn't play Amazon Music.
Question edited for clarity and add CAPS.It can only stream from your phone but can be voice operated by Amazon Voice operated hubs or from your phone.With Chromecast built-in™, you can stream your favorite music from your phone, tablet, or laptop right to your Mondo Elite. Easily control your speakers with hundreds of apps you already know and love from your iPhone®, iPad®, Android™ phone or tablet.Specshttps://gracedigital.com/products/mondo-elite..
3/23/2024 6:34:34 PM • Amazon Computers... • Answered on Mar 23, 2024
On grace mondo elite internet radio cannot get presets to play my amazon playlists - song pops up but music doesn't play unless I play it through the phone app - what step am I missing?
To troubleshoot streaming issues: Confirm that your device is connected to Wi-Fi or a mobile network. If using a mobile network, confirm that the Amazon Music app settings allow for Cellular. Force stop and reopen the app.
3/22/2024 7:42:15 PM • Amazon Computers... • Answered on Mar 22, 2024
Amazon Kindle DX 2nd Generation Logo
Popular Tags
16 questions posted
Top Amazon Computers & Internet Experts
vince
Paul Carew
Are you an Amazon Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Kindle Amazon
  • Kindle Amazon
Most Popular Question
get free instruction manual
  • Computers & Internet
