20 Most Recent
TP-LINK 11b/g Wireless Adapter Questions & Answers
My TP-Link 11b/g wireless adaptor
i think your network is hidden, just look for the hide or show option
and yuo need to reset the adapter, software
its easy to show hard to explain
I get bad reception with my TP-Link PCIe Wifi
Often times the antennae on these routers come loose. Ensure that the antennae are firmly plugged in.
Try also changing the channel. Routers have 11 to 13 possible channels and most default to 1 6 or 11. Try a different number to reduce interference.
Physical construction of your house can hinder wifi reception. This is often subjective and your best bet would be to move the router around the room or into a different room if possible.
How to configure TP Link router connected to Thomson TWG850-4 ?
have you got two dhcp servers running ?
turn off dhcp server in wireless router
and use the one in the Thomson TWG850-4 Residential Voice Gateway.
make sure ip address in wireless router is different to the Thomson TWG850-4 Residential Voice Gateway. make it one higher on last digit of ip address
make sure dhcp does not lease out this ip address.
9/10/2021 10:58:38 AM •
TP-LINK...
Answered
on Sep 10, 2021
Error code: 4801
Error code: 4801 "System can't satisfy the requested min upstream rate. Please input again."
10/24/2019 12:56:49 AM •
TP-LINK...
Answered
on Oct 24, 2019
How do I set up a TP-Link wi-fi extender?
Hello, indicate model of the TP-Link that you are commenting, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola, indica modelo del TP-Link que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
6/4/2019 12:55:55 AM •
TP-LINK...
Answered
on Jun 04, 2019
