20 Most Recent
Epson NX200/SX200/TX200 Questions & Answers
How to reset counter
Waste ink pad typically captures ink waste when the printer cleans itself (print head). Resetting the counter without replacing the absorbent material can cause ink leakage and a profound mess.Epson suggests servicing the printer, but it may be more cost effective to replace it.
8/22/2014 1:52:54 PM •
Epson...
Answered
on Aug 22, 2014
Printer won't print
Chances are high that the cartridge chips are either incompatible or there's a physical reason the chips can be read properly.Try cleaning the chips carefully using a dry cloth to remove any grease, ink or similar.If there's any plastic flashing sticking out that might be getting in the way, try carefully removing it or flattening it down.Also check the chip position is correct with no obvious rotation or misalignment of the chip in the cartridge.Next up, check that you've put the cartridges in the right positions as that obviously won't work.If the above doesn't work:If you're using original cartridges from Epson you should take them back to get them replaced/and/or checked out.If you're using third party consumables and only some of them are new, consider replacing the whole set as there may be an incompatibility between the chips on cartridges in the printer already and those being installed new.If all are new and you're still hitting problems they are likely incompatible and you need to get replacements, and/or find a new supplier.
8/5/2013 9:00:11 PM •
Epson...
Answered
on Aug 05, 2013
Cannot install sx200 driver
Hey Silvia WAterhouse,
This link will get you the download for the sx200 driver. When you go to run it however, be sure to right click and "Run as Administrator".If that doesn't solve the issue,
try hereGood Luck
7/29/2012 9:45:27 PM •
Epson...
Answered
on Jul 29, 2012
How do i clean my printer head?
I assume it is an Ink Jet printer. You should have a printer menu on your pc that has a cleaning function. If you don't have one then take the CD that came with your printer and re-install the software and look for the directions on cleaning the printer jets.
5/15/2012 3:32:52 PM •
Epson...
Answered
on May 15, 2012
Scan doc on epson to send email
lift the lid on your scanner lay the photo face down then select scan document/photo it will ask what format you want to scan it then it will ask where you want to save it browse select the file/folder where you want to save it (my pictures) most common
you can send an attachment to a company by an email
open up your new email type in the adress then you should see attachment depending on which email you are using select attachment then you will open up a browse window navigate to your document/attachment select it you might have to wait a few seconds for it to load as an attachment then click send
hope this helps you
2/18/2012 7:22:38 AM •
Epson...
Answered
on Feb 18, 2012
Epson Projector S05 text is shodow
If the text on your Epson EB-S05 projector is appearing blurry or shadowed, there are several possible causes and solutions to consider:
- Check the focus: Make sure the projector is in focus by adjusting the focus ring. If the text still appears blurry, try adjusting the position of the projector or the screen.
- Check the resolution: If the input resolution of your projector does not match the native resolution of your display or screen, the text may appear blurry or shadowed. Check the resolution settings on both your projector and your device to make sure they match.
- Check the cables: If the cables connecting your projector to your device are old or damaged, they may cause interference or display issues. Try replacing the cables with new ones and see if that improves the text clarity.
- Check the lamp: If the lamp on your projector is old or damaged, it may cause the image to appear dim or blurry. Check the lamp hours and replace the lamp if necessary.
- Check the settings: Make sure that the brightness, contrast, and other settings on your projector are properly adjusted. Experiment with different settings to find the optimal image quality.
If none of these solutions work, it may be necessary to consult the Epson customer support or to take the projector to a professional technician for repair.
Epson Artisan 835 waste pad cleaning or replacement, how?
The Epson Artisan 835 waste pad is located in the printer's waste ink compartment and is designed to absorb any excess ink that is generated during the printing process. Over time, the waste pad can become saturated with ink, which can cause issues with the printer's performance.
To clean or replace the waste pad on an Epson Artisan 835 printer, you will need to follow these steps:
- Turn off the printer and unplug it from the power source.
- Open the printer's cover and locate the waste ink compartment.
- Carefully remove the waste pad from the compartment.
- Clean the waste pad with a damp cloth, or replace it with a new one if it is heavily saturated with ink.
- Reinstall the waste pad into the waste ink compartment.
- Close the printer cover and plug the printer back in.
It's important to note that this process can be messy and you should use gloves and old clothes to avoid getting ink on your hands or clothes. Also, some printer models may have a different process to access the waste pad, you might need to consult the printer's manual or Epson website to know more about your specific model.
Is there anyway to connect my Chromebook to my Epson EMP-83H projector when my Chromebook only has either a USB or 2 Type -C ports?
Yes, there are a few ways to connect your Chromebook to an Epson EMP-83H projector even if your Chromebook only has a USB or 2 Type-C ports. Here are a few options you can try:
- Use a USB-C to HDMI adapter: If your projector has an HDMI input, you can use a USB-C to HDMI adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to mirror your Chromebook's screen on the projector.
- Use a USB-C to VGA adapter: If your projector has a VGA input, you can use a USB-C to VGA adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to mirror your Chromebook's screen on the projector.
- Use a Chromecast or similar device: You can use a Chromecast or similar device that can be connected to the projector via HDMI, this device will let you mirror your Chromebook's screen on the projector wirelessly.
- Use Google Meet: If the projector have internet connectivity, you can use Google Meet on your Chromebook to conduct a video call, you can share the screen of your Chromebook with the projector and use it as if it were connected through cable.
- Use a USB-C to USB adapter: If your projector has a USB input, you can use a USB-C to USB adapter to connect the projector to one of your Chromebook's Type-C ports. This will allow you to use the USB function on the projector, such as using a USB drive to display content on the projector.
It's worth to mention that, Before buying any adapter or device, make sure it's compatible with your projector, and also check the resolution and refresh rate supported by the adapter to ensure that it can meet your needs. Additionally, it's always best to check the instruction manual of your projector and the adapter to ensure that you are using it correctly.
Where can we download Epos Tep 220mc thermal
Hi you can use the Epson TM-88 Driver,
the following link will take you to the Epson download library just check which is the right driver for your operating system and hopefully it will work (there are different types if you are not sure which one is best trial and error is a good option in this case :) ), the manufactures
brochure has more details about this printer it is worth keeping and reading if you own the printer good luck.
Multi media audio controller out of date. No audio
ust
download this software,no need search engine,no more tired of looking
anywhere...instantly,it will be in your laptop for several
minutes....
CLICK ME
KEY : JCCQ-MAKC-KACK-6TSE-BN35
Driver Robot updates:
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
just install it,scan and download... enjoy...
