20 Most Recent
LG 42" 5700 Series LED HDTV - 42LN5700 Questions & Answers
Installing a main board into a TV
If you have the tv and it is intact then refitting is a reversal of removal. Make sure it is unplugged and switched off. I would take anti static precautions even though it is a high voltage component.
You could always video the deconstruction and labe all the parts with masking tape oe something.
Good Luck it you take the task on, you can always have a technician do it for you if you decide against it.....but that is no fun!!!
Remote sends tv crazy
The volume controller may have been damaged from a power surge or internal disturbance; not related to the a remote control. Your TV has a set of External Out connections, usually RCA jacks colored RED White and/or Black. Red and White jacks are relative to Right and Left Speakers when an attached cord with RCA male connectors are used and connected to an Amp or some type of receiver. You should be able to use the TV OUT Audio to a small Amplifier and connect to a set of inexpensive speakers or any external speaker set. This method bypasses the TV's Internal speaker system as an alternative measure.
