20 Most Recent LG 47" 5400 Series LED HDTV - 47LN5400 Questions & Answers
2answers
How do I know if my backlight on my LG tv is working
Wait until it is very dark. All lights out. Switch on. The screen should perceptibly change from black to dark grey. Perhaps you will see some light leakage near the edges where glass meets plinth. And there is the T test where you touch the screen with the back of your hand after it's been on for a while. Although LED backlights are cold, they do generate some heat. So a perceptible change in temperature usually indicates that the backlight is functional.
12/3/2022 12:10:44 AM • LG 47" 5400... • Answered on Dec 03, 2022
Can I replace screen on my LG 47LN5400? It fell over this weekend and broke the screen. I'm pretty good at fixing things, can I buy a replacement screen anywhere for this?
Screen will exceed the value of the set. If it is even available. That is the single biggest cost in tvs. Even u Der warranty few manufacturers replace them. Most replace the entire set.
10/31/2016 7:37:23 PM • LG 47" 5400... • Answered on Oct 31, 2016
What keeps burning out the inverter board on my LG flat screen t.v. model #LG-47LN5400? Just replaced 1 week ago and it's doing the same thing. getting power and sound but no picture. Thank You.
Then you have another board that is shorted or causing an overvoltage condition that is destroying the new PCB
10/27/2016 9:58:02 PM • LG 47" 5400... • Answered on Oct 27, 2016
Tv stopped working
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2/14/2016 12:20:18 PM • LG 47" 5400... • Answered on Feb 14, 2016
I have lg 47 tv that sud pic stop has sound when you turn on you see a light for sec
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
11/24/2015 8:56:37 AM • LG 47" 5400... • Answered on Nov 24, 2015
What parts do I need to order to repair a no video issue on this model TV?
Typical case of Timing control board blew (T-Con). it could be due to electrical shock on DC-DC converter chip. You might need to swap it for a new one. Good Luck!
10/15/2015 11:30:27 PM • LG 47" 5400... • Answered on Oct 15, 2015
Which part needs replacing on the TV? See details.
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
10/15/2015 9:29:28 PM • LG 47" 5400... • Answered on Oct 15, 2015
3answers
Fuse diagram for a LG plasma model pdp42v80201
The screen blank out
4/7/2024 11:03:07 PM • LG Televison &... • Answered on Apr 07, 2024
LG Plasma TV is not displaying picture when it is turned on
This is the Power Board for it. check those 6 electrolytic Capacitors on the right for bulging or splitting. Don't buy it blindly, it's a guess. The output voltages with a digital multimeter. https://applianceparts.com/item/10217204/LG/EAY62812602/ Many parts are obsolete. eBay has used boards, but they are risky because they are out of scrapped sets. https://www.google.com/search?q=50PN5300-UF+power+board We have a television expert named Larry, but I haven't seen him for a while. This used to be my advice https://www.fixya.com/support/r29790007-repairing_own_television ..
3/30/2024 8:59:29 PM • LG Televison &... • Answered on Mar 30, 2024
3answers
DVD reading problem on a LG DVD5083 DVD player.
Maybe the disk is not compatible with the DVD player version
3/24/2024 9:16:41 AM • LG Televison &... • Answered on Mar 24, 2024
How do I program my DVD video remote control to my LG Blu Ray surround sound player please?
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 4:25:52 PM • LG Televison &... • Answered on Mar 19, 2024
LG BD590 250 GB HD Network Blu-ray Disc Player. How to make LG BD590 region free?
Question edited for a lot more clarity. All in the link https://www.google.com/search?q=LG+BD590+make+region+free ..
3/17/2024 3:28:16 AM • LG Televison &... • Answered on Mar 17, 2024
How can I program my LG DVD remote control COV33662806 to my LG 55 Roku television.
You can't, the LG DVD Remote is single frequency. If you are lucky, the LG Television Remote, might control an LG DVD. If you have lost a remote, have a read of this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/15/2024 11:09:16 PM • LG Televison &... • Answered on Mar 15, 2024
Could you help diagnose the issue with my LG TV MODEL 65UN7300AUD that does not power on?
If you would like to share any clues, yes. Checked power going in, I presume. Any indicator lights? If yes, how many times does it flash?
3/15/2024 7:15:50 AM • LG Televison &... • Answered on Mar 15, 2024
2answers
My LG DVD/CD receiver Model:LH-D6246,Shows disc 'error' when I load a dvd or cd disc but the radio plays very well please help
faulty dvd reading lens,should be change by expert professional
3/14/2024 12:44:09 AM • LG Televison &... • Answered on Mar 14, 2024
How to activate universal remote control AMELY AD-UL101S with LG TV Brand or other brand?
Question edited for clarity and add maker. No one uses Universal Remotes these day. You buy a Remote that is a Copy of the original. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote The AMELY is a very cheap and nasty Chinese Remote and they don't supply instructions!! https://www.amely.cn/AD-UL101-S-AMELY-unviersal-TV-LCD-LED-remote-control-p636185.html Codes are decided by the brand of television. This is for LG https://www.google.com/search?q=universal+remote+codes+for+lg+tv ..
3/3/2024 4:57:30 PM • LG Televison &... • Answered on Mar 03, 2024
LG DVD Player - DSI-8555 manual please?
It appears to be a model made for the India market. https://www.google.com/search?q=lg+dsi+8555+manual This is the only service manual that is related. If the display is not working, look on the back of the display board for a split or bulging electrolytic capacitor.
SERVICE MANUAL
Encompass Parts https://research.encompass.com > ZEN PDF This manual was prepared for use only by properly trained audio-video service technicians. When servicing this product, under no circumstances should the ... 109 pages
3/2/2024 7:45:46 PM • LG Televison &... • Answered on Mar 02, 2024
My children have misplaced remote control of LG TV now there's child lock. how can i turn off child lock without a remote control?
buy replacement remote google your tv model number follows by remote.
2/25/2024 6:07:37 AM • LG Televison &... • Answered on Feb 25, 2024
LG 47" 5400 Series LED HDTV - 47LN5400 Logo
9 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
keeps burning out inverter board lg flat
  • Televison & Video
